The battery and the starter motor are just two of the things subjected to wear and tear with frequent restarts. However, there's also the contention that, provided that these are in serviceable condition, there will be no adverse effects with frequent starting as the manufacturer suggests. If at all, the cost of restarting adds some $10 (PhP500++) a year to the cost of driving, money supposedly recovered several times over in fuel savings. See
here.
Diesel engines, by nature, are less prone to suffer internal wear than gasoline engines because of two things:
1. Diesel engines are built to withstand higher levels of stress, since they require a high compression ratio to ignite the air/fuel mixture.
2. Diesel fuel is sprayed into the engine during the combustion cycle, which lubricates the cylinder walls, thus reducing friction.
Not sure if it has any impact on turbo, though.
