Results 1 to 18 of 18
    Aug 2004
    Hello Tulong po,
    Whenever I hear the usual heavy "tik" sound (indication of one of the fans turning on; A/C returning from thermostat) my RPM (while gear is at "D") goes down from 800rpm to around 350-500rpm and usually lasts half a second. When it does that, the thing shakes violently a bit.
    Ano po kayang cause and fix dito? Lately ko lang naexperience ang problem na ito eh.
    Thanks!
    May 2005
    ganyan nangyari sa Lancer GTi namin dati. Check ng Mitsu tehcnician ang servo kit, throttle body & ecu. Servo kit ata pinalitan dun sa amin.
    More than likely that it's just an issue of tuning. Either way, it's nothing to worry about.
    Sep 2005
    same thing happen to my ESI bagsak RPM pag ON ang AC init sa traffic. ung IDLE UP ang problema. convert nya ng TOYOTA(big body) IDLE UP 450pesos lang compared to HONDA libo and so far ok naman. Madami na akong nakitang ganoon ang ginawa nya di ko lang alam kung pwede sa car mo. mukha nga lang naBYPASS operation na engine ko kci dami tube na ginamit per ganda naman tignan kung maayos ang gawa.
    May 2005
    baka po sira na rin ang engine support
    pwede ang idle up ng toyota sa esi? pano? ano itsura?
    Nov 2006
    pare san mo pina-tira ito? mukang ganito din ang kelangan ko ipayari sa ESi
    ko eh. magkano inabot, parts & labor?
    TIA!
    Quote Originally Posted by ruelsdcz View Post
    Sep 2005
    sir, PM ko na po ung info na kailangan nyo. im still not sure kung matutuloy ako sa pampanga this week if ever post ko dito then usap tyo kung interesado ka.
Idling goes down from 800 to 500 RPM...
