Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
    Aug 2005
    #21
    [quote]it depends kung ano ride mo. sa akin yung idle up is below the carb (toyota corolla 12 valve). may screw yun which you can turn to set the idle up. dun sa diesel ko naman (mazda b22), may screw rin na ia-adjust. its located at the driver side, beside the engine block at the back of the the fuel injection pump.[/pump]
    idle up setting is totally independent from the idle setting ryt?say your idle hovers at 750-800 on A/C off,when you switch the A/C on, idle up kix in and ups the idle at 900 or 1100? already adjusted the A/F setting pero ayaw tlga umakyat ng mataas idle ko.
    Aug 2005
    #22
    Hehehe.. nice thread.. isa din ako sa mga praning and paraniod sa idle.. hehe.. bro alam nyo easy lng yan.. yung screw at the back ng carb dalawa yun isa sa air and fuel (sa ta-as )mixture and isa yung sa idle ng engine (sa baba) tama ba me?.. pwde lng yan DIY at may ma learn kpa.. mas maganda mag change ng idle kpag mainit yung engine or nka warm up na kasi yung ang saktong idle time..
    regarding sa A/F mixture wla talaga akong alam dyan.. pero inikot ko nlang prang feel ko na tama na yun pra sa idle ko..
    sa engine IDLE sakin kapag may aircon 700 RPM kasi kpag mababa nman hindi malamig yung aircon like hindi kumagat sa 'minor' .. tanong ko lng po ano ba talaga tamang IDLE kpag Aircon off and aircon ON?
    Jun 2005
    #23
    After nung last na check up ng kotse ko, minsan rough yung idling. may ibang araw naman na tama lang. bakit kaya ganun? parang mas maiintindihan ko kung consistently mababa, pero hindi ko maintindihan kung bakit within isang araw, paiba-iba yung idling. (constant naman yung aircon settings ko...)
    thanks
    #24
    [QUOTE=dj_ryankilmore]
    kung ayaw umakyat then baka may problem yung vacuum mo at idle-up mechanism as what sir afrasay mentioned. ipa-check mo na lang sa mekaniko mo.
    #25
    Quote Originally Posted by jarx
    thanks
    carb ba makina mo??? if yes then you can start by checking the carb baka kelangan nang linisin. tignan mo na rin yung fuel filter mo kung may bumabara. ang daming pwedeng i-check hehehehehe. ang bagsak nyan kung talagang di mo makita kung saan ang problema dalhin na sa mekaniko
    Jul 2006
    #26
    bro's, sa Lancer gli .. san b adjustment ng aricon? mababa rin kc yung idling ko pag naka-aircon
    Jul 2006
    #27
    saan ba inaadjust ang idle up ng 4af kapag nakaaircon na?
    #28
    Quote Originally Posted by afrasay View Post
    700rpm when the aircon is on.
    Too low, it will still vibrate at this setting. Idle should be at least above 900rpm or so when the a/c is on.
    Feb 2005
    #29
    Quote Originally Posted by Steve1227 View Post
    Bro, Lancer gli is EFI na so i-pa check or palinis mo yun idle up servo may gear yan bka marumi na or sira na yun mga gear.
Idle-up setting
