Page 1 of 2 12 LastLast
Results 1 to 20 of 29
    Mar 2003
    i have searched through the idle-up topics here but didn't find the answer i really need.
    ano po ba talaga ang correct setting ng idle up? sakin kase pag nag on ang a/, tumataas yung rpm ko ng about half a centimeter to a point that i can really feel the jerking at kapag nakastop, ramdam yung sudden vibration pag on ng compressor. ok lang ba ito? or dapat d nagbabago yung rpm kapag nag on ang a/c for as long as it will no go down (otherwise defeating the purpose of the idle-up mechanism)
    TIA
    The idle up mechanisms (vacuum and vacuum switch) compensates for the load that your aircon adds to your engine. Say if you idle smoothly at 700 rpm (differs from engine to engine) and you turn your aircon on, your rpm would drop to 650 or 600 which in turn would make your engine vibrates. What the idle up mechanism do is to increase your idle rpm everytime your A/C compressor turns on. It's like a foot pressing on the accelerator pedal (automatically of course) so your engine won't vibrate. IMO, idle up should be adjusted to the same ea. 700rpm when the aircon is on.
    Mar 2003
    Thanks sir afrasay, that pretty much answers my question -- so dapat talaga i compensate lang yung added load, and should idle at same rpm, mine idles at 750 and goes to around 800 kapag nag on ang a/c kaya cguro lakas ng jerk.
    mejo O.T....given ng 750 ang RPM ko without lights on...pero at night nasa 700 lang because of the added load ng headlight...normal lang ba yung ibinababa nya?
    TIA!
    Ok lang yan yan. Pero i would suggest to adjust it with the engine warm-up and with the headlights on. Do you have upgraded lamps? 100w? Some cars with small engines have idle up compensators just for the park/headlights like my Samurai. Jerk? baka malambot na engine support mo.
    Beetols,
    Praning ka lang. Welcome to the club! Hehe. Yan sila Alfred, Otep, at Ungas, masarap kulitin yan kasi ambilis sumagot. Hehe.
    About your idle up setting, yup, dapat same as normal idling without AC, nakapagtanung tanong na rin ako. Ikaw nalang mag-adjust...madali lang naman yan.
    Alfred,
    Si Beetols yung friend ko na nameet mo sa Marikina Badminton.
    ah the guy with the pickup, i remember na.
    May 2005
    yung sakin pag naka on yung A/C tumataas up to more than 1000 rpm. pag nako off mga 800 lang. pano ko ma-aajust?
    Feb 2005
    bakit yung sakin baligtad? pag nakaengaged a/c nsa 650rpm pro pag disengage taas bigla sa 1100 rpm? help!
    Box Type,
    Malamang wala kang Idle-up. Alam ko yung sakin wala din eh. I drive a local trooper 98 model.
    Aug 2003
    mine naman is 400rpm when off ac. it will jump to 800 when ac is on. Do you think kelangan ko din pa-adjust? btw, 1.3 carb engine nga pla akin. thanks.
    Quote Originally Posted by box_type
    mali yung idle setting mo. 1100 rpm during idle is too high. try mo ipa-adjust to 700-800 rpm yung idle mo.
    the reason kaya bumababa yung rpm mo when the a/c is on is that di rin naka-set ng maayos yung idle up. punta ka na lang sa a/c shop they can adjust the idle and idle up settings for you if you don't know how to do it.
    Feb 2005
    thanks sirs Jim and Djerms i think im gonna visit my a/c tech this weekend mabuhay!
    hehe...avalanche of problems na. basta make sure may vacuum and idle up switch kayo before making adjustments.
    Feb 2005
    ot, apektado rin ba ng rpm lamig ng aircon?
    Mar 2003
    *afrasay -- i just have stock lights; if i do the adjustment when warm and head light on, then kapag pinatay ko na eh tataas naman mashado ang rpm; slight lang naman ang pagbaba ng rpm needle kapag headlight on, and battery charging is just right (around 13-14); neways, i'll try to make minimal adjustments nalang. thanks!
    di naman, maliit lang ang load sa engine ng headlamps. kaya ok lang.
    Aug 2005
    saan inaadjust ang idle up?
    May 2004
    Quote Originally Posted by graphire
    400rpm is bad for your engine sir, subukan po nyo paadjust 700rpm up
    Feb 2005
    Quote Originally Posted by dj_ryankilmore
    same question here...
    it depends kung ano ride mo. sa akin yung idle up is below the carb (toyota corolla 12 valve). may screw yun which you can turn to set the idle up. dun sa diesel ko naman (mazda b22), may screw rin na ia-adjust. its located at the driver side, beside the engine block at the back of the the fuel injection pump.
Idle-up setting
