tsikoteers, help naman.
may dad's 94 accord nagiidle up every time you shift gears.pinalinis na throttle body. hindi na namin malaman kung bakit ganon.
thanks sa mga magreply...![]()
m/t po yung accord 94.
ganito po yung nangyayari, from 1st gear to 2nd gear habang shifting ngrerev up your engine. example... kung shift at 2500 rpm, shoot up sa 2700 rpm while shifting (not stepping on the gas). same goes with 2nd to 3rd and so...
thanks po sa magreply...![]()
sir speedy, yung throttle lang po yung pinalinis...
would a dirty manifold and/or iacv be the culprit?
the iacv yes. the intake manifold won't affect i pero magdudumi ulit agad yung tb and iacv if hindi mo isabay sa cleaning.
sir speedygot same problem also but mine is a toyota corolla 92 gl 1.6, minsan in the moring pag gagamitin ko start form low idl to high idel tapos pag na ilabas ko na ng garahe umanfar na ako ok nanaman ang idl ko lower then 1000rpm parang 800 0r 900 something like that. tapos ganun nga pag nag shift ako to 1st 2nd to 3rd pag tapak ko sa clutch bitaw sa gas tumataas rpm ko why?
if it's carbbed, have it adjusted... if it's efi it may be that there's too much air in the system so adjust din the idle air valve/knob.
matanung ko narin? diba ganun talaga engine characteristic ng vtec? ung k20 ng crv ko ganun din cya eh, or di normal to? pero kung around 3000 to 4000rpm di naman cya tumtaas ung idle, san po ba nakalagay ung iacv? makalikot nga...
Sir archie123456789 tanong ko lang po kung nafix niyo itong problem na ito and ano po ang ginawa para maayos? I have a gen2 crv and I also have the same problem.
Sir Speedyfix is this normal?
mrbogus3000,
manual tranny ung gen2 crv mo noh? same tayo, tumataas ung rpm pagshift to higher gear. pero i did notice kung abot ng 3000rpm before shifting, di cya ganun
Redpitz,
Oo bro manual tranny yung sakin. Hindi naman ako umaabot 3000rpm. lets say shift ako nang gear nasa 1500rpm when i step on the clutch taas siya nang 1700 or 1900rpm. also pag pababa ang road tapos nag rolling lang ako taas din siya. pero once I turn on the aircon wala naman akong ganitong problem.![]()
yung sayo ba napacheck mo na? normal lang ba ito?
parehong pareho tyo po. di ko pinapacheck ksi kala ko ganito ung vtec na engine, dba nga kasi paglow rpm single valve lang gumagana kaya kala ko baka tumataas compresion nya kaya ganun. naghahanap ako ng 5w-20 na oil baka kasi sobrang pressurize ung nagpapagana sa vtec pero theory ko lang, sbi dito iacv dapat linisin, hanapin ko pa un... anyway pagmay solution ka na paki post naman, same with me...
o nga pala, bat sobra baba ng rpm mo pagmagshift? look po your manual, proper shift point niya nakasulat po dun. God bless!
mga pips, sorry hindi ko na napansin yung thread. to answer your questions, ok na po yung accord namin... pinalinis lang IM, iacv, and inulit linis ng TB. ok na...
medyo matagal lang ginawa pero sulit sa result. hehe
hth
