Results 1 to 7 of 7
- Oct 2009
- 249
August 9th, 2014 08:05 PM #1Mga paps tanong ko lang, ilang liters of oil ang natitira kapag nag drain during oil change? Kasi nag oil change ako kanina para sa vios 1.3 ko. Sabi sa manual oil capacity is 3.7 liters with oil filter and 3.4 without oil filter. Bakit kanina pag lagay ko ng 3 liters of oil. Yung dipstick ko is nasa maximum na? Yung previous chamge oil ko eh sa casa amd they use 3.5 liters and pag tiningnan mo sa dipstick eh sobra sobra sa maximum level. Ok lang kaya yun na 3 liters lang nilagay ko? Tnx
- Apr 2010
- 742
August 9th, 2014 10:11 PM #2Did you have your oil changed when the engine is warm or not? Probably casa uses air compressor to speed up oil changes kaya mas maraming oil ang natatanggal. Basta check your dipstick na lang if it follows spec.
- Oct 2009
- 249
August 9th, 2014 10:34 PM #3The engine is warm, bali dun na lang ako sa dipstick nag rely kasi na maximum level na sya on 3 liters of oil. Hindi ko na dinagdagan
- Oct 2009
- 2,271
August 11th, 2014 03:04 PM #4paandarin mo muna para mag circulate ung mga langis.
saka mo sukatin ulit ung langis ..
ako pag nag chechange oil pinapainit ko muna ung makina..
para lumabnaw ung langis,para madaling bumaba
- Oct 2009
- 249
August 11th, 2014 07:57 PM #5Salamat paps, after filling in 3 liters of oil. Pinasetlle ko mag damag. The next morning sinukat ko sa gitna sya ng min and max sa dipstick. Test drive ko. Mas tumahimik yung takbo ng makina. Then dinala ko slex. Yung engine growl nya mas tahimik ramdam mo na lang bumibilis ang takbo. Masama po ba pag mas tahimik ang engine? Sorry wala masyado pa experience
August 11th, 2014 08:02 PM #6
- Oct 2009
- 249
August 11th, 2014 08:32 PM #7Salamat po sir, simula kasi nung kinuha ko sa casa normal engine noise po.. assume ko po na normal yun Dati po kasi lagi lampas sa max ng dipstick yung sukat ng oil. Akala ko ganun talaga since casa naman ang nag change oil. Tapos nung ako na nagpalit. Eh tumahimik ang tunog ng makina... salamat po ulit sa info sir.. God bless po
Specs, prices, features: Everything you need to know about the all-new Hyundai Kona | TopGear PH...
Hyundai Kona (2nd Gen)
