Results 1 to 15 of 15
    Jan 2013
    Mazda 3 2005 1.6l.
    patulong naman po regarding my car. start up rpm is normal, pag nareach na normal operating temp. ng vehicle rpm fluctuates (w/ load gear in D and a/c on) pero hindi siya namamatay. pag walang load (gear in N & a/c off) rpm surges to more or less 2000. if you try to rev the engine to about 3k to 4k the rpm goes down but not below 2500. if you try to rev up to 6k and release the accelerator pedal it goes down to normal idling (but not always), otherwise rpm fluctuates again. I've already changed MAF sensor, IAC valve, and already cleaned throttle body but the problem still persist. patulong naman po, ayaw kung dalhin sa dealer kasi diagnosing pa lang mahal na...
    Sep 2012
    Since nagawa mo na yung basics... Next thing to do is have it scanned ng obd scanner para malaman kung may iba pang problem.
    Sent from my Windows Phone 8 using Tapatalk
    Jan 2014
    very good idea and advise bro..
    Jul 2014
    Bro automatic ba gear mo
    Jan 2013
    Quote Originally Posted by jodski View Post
    Thanks Sir Jodskie for the reply...sige po gawin ko.
    kung meron po bang vaccuum leak possible ba na magsurge din rpm?
    Posted via Tsikot Mobile App
    Jan 2013
    Quote Originally Posted by mrjeff View Post
    yes sir...
    Jul 2014
    Dami pwede pgmulan ng trouble bro... Pero try mo hugutin socket wire ng TPsensor kung di ka nka TAC motor ang throttle body mo.. Jn mo malalaman kung mg stable sya ng idling... Pwede din ung socket ng MAF bunutin mo malalaman mo din kung mg stable din ang engine. Kc pwede sa CMP,ECT o mechanical gaya ng leak ang gasket mo... Sa gear pwede sa TCC... Sana di sa PCM kc kadalasan ang makina ng Mazda at ford jn ang problema..
    Jan 2013
    thanks mrjeff...try ko yung throttle position sensor, yung mass air flow sensor bagong palit lang yun eh. hopefully basic lang problem nito.🚘 wala pa din kasi ako time magpascan kung may stored faults ang ecu, sa weekend pag maisingit.
    Jul 2014
    Your welcome bro... Magkano ba magpascan ng car??
    Jun 2011
    Huwag ka munang palit ng palit ng electrical parts hanggat di na scan, malalakihan ka dyan. Makikita naman yan sa scan kung electrical parts ang may problema. Pero ang leak, fuel presure regulator at fuel filter di makikita sa scan kaya check mo muna ito.
    Sep 2012
    Check mo nga gas pedal mo kung iangat mo ng konti is biglang bababa rpm... Tignan mo rin kung medyo matigas tapakan... After that, check mo rin kung agad bumabalik pataas kapag nag depress ka ng accelerator...
    Yan na lang kasi ang last basic problem na naisip ko based sa kwento mo.
    Obd scanning naman usually nasa 1,200 and up depende kung saan ka nagpatingin i'm not sure lang kung nagbaba na ng price these days...
    Sep 2012
    If ever you find out that the culprit is medyo nag stuck gas pedal, ipapabaklas mo lang yung cable nyan then put oil to lubricate.
    Jan 2013
    sir jodski ok naman accelerator pedal at cable di siya maganit.
    Aug 2014
    sana bago ka nagpalit pina scan mo muna. mas mahal ang MAF sensor at IAC valve kesa magpa scan. hirap mang hula ng parts.
    Aug 2014
    pahabol lang sir, yung sa akin ganyan din ang problema (glxi93). nilinis ko yung trottle body, servo, tapos TPS, tumpak! umayos na idling nya cold or hot. basic muna gawin mo bago ka magpalit ng parts.
    just sharing.
rpm surges/fluctuates
