Results 1 to 6 of 6
    May 2010
    Mga sirs, ano po ba ang tamang level ng tubig ng baterya? Nung binili ko po kasi yung auto ay battery w/ maintenance lang ang nilagay, at tsinek ko yung tubig ng baterya halos nasa kalahati yung mga tubig nung 6 slots. Dapat po ba na laging puno yun o tama lang na nasa kalahati ang tubig nung anim na slots na yun? Thank you
    Jul 2003
    dapat puno pero hindi naman nag-uumapaw. dagdagan mo na lang. baka tinipid nung binili mo. gamitin mo yung tubig na pambaterya talaga.
    meron kasing dry charged battery na nilalagyan lang ng tubig pag nabili na at gagamitin na. baka dun nagkulang ang binilhan mo.
    May 2011
    i just do hope hindi pa nabubura yun level marks nyan, me MAX - MIN nakalagay dyan. IIRC, nasa p10-15/liter lan ang distilled H2O for batteries. ;)
    Btw, batt should last at least 24mos/2yrs (beyond that is sulit na).
    Quote Originally Posted by arvin.diesel View Post
    Typically the MINIMUM water level in the battery should be enough to cover the battery plates and MAXIMUM just touch up to the marker for each battery cell/hole/tube/etc. As long it's between those two points, it should be fine.
    Feb 2009
    the battery level for transluscent battery case is paint printed on the case itself, for batteries with black plastic case, there are split tubes extending down the filler hole. when the electrolyte reaches these split tubes and the electrolyte surface (top) appears distorted from capillary action, there should be enough electrolyte. don't overfill though, the spilled electrolyte is about 64% sulfuric acid and will corrode the battery tray and all metals it comes in contact with
    Oct 2011
    maintain mo puno sir dun sa baba lang ng hole/cap. just pour in distilled water.
Ideal na level ng tubig ng baterya
