Its just the reverse. Poorer filtration due to larger micron rating, lower bpv youd have problems if system runs on higher pressure, drainback valve is useless since system is designed for full flow multi-pass probably doesn't sit above the sump just like most motors do. Its imperative to know the specs of both filter/engine lubrication system before substituting a filter.
