Results 1 to 6 of 6
    Mar 2013
    2009 Montero Sport Diesel 3.2/ 4M41 engine,
    Humming noise problem please help!
    Feb 2009
    Quote Originally Posted by MPHSPC View Post
    capable and willing to help. give more info, details, statistics, numbers, situation when symptom appear, what you noticed, intensity, frequency, location, mitigating factors, etc. more details makes it easier to help you
    Does it come out at a certain speed? At a certain RPM? Does it run along with the RPM range? When the car is moving or stationary? Did anything happen to the vehicle before it came out (i.e. flood, engine wash, change any part/tires, bad pothole?).
    Sep 2008
    Baka galing sa fuel injector pump.. naranasan ko yan noon though in my case gas engine yun when E10 was introduced. at first humming was low until it gets annoyingly loud/noiticeable! switch back to regular unleaded then nawala kusa...
    in addition.. are the wheels aligned? are there signs of uneven wear on the wheels? is the transmission/differential oil at level? wheel bearings perhaps?
    Aug 2017
    Sir, drid you fix or identify the humming noise from your Monty SE? Please share it. Ty
Humming Noise
