i'm planning a DIY oil change...the engine flush can has instructions, pero any other tips you can share? Since the damn thing is acidic, i'm not very trusting of the directions on the can B).
Ang sabi kasi, run engine at idle until normal temp, add the flush, run the engine at idle for 5 minutes, then drain. What sort of container should i use to store the oil/flush? Is it safe to use your hands to remove the oil drain plug? Baka naman after that e count to 7 na lang ang kaya ko B).
Paano pala magdispose nun after you're done? Would adding milk/alkali help neutralize the acid?
How many km in between ba kailangan i tune up ng car na 13-14 y/o(one that hasn't been taken cared of well until recently)? Aroun 90km na po sa odometer
