Results 1 to 10 of 39
December 18th, 2003 06:19 PM #1
hehe kakapa change oil ko lang kanina....just wondering how often should you engine flush and additives? ang sabi saken alternate daw. comments??
December 18th, 2003 07:43 PM #2
nag aadditives ka!?what do you use!?
i only used the flush ones...i dont believe na kailangan sila...ang sabi sakin dati ng mekaniko ko na nag ooil change..pag shifting from synthetic-normal or v.versa ka lang daw kailangan mag flush.....but if same oil..no need daw...so thats what i am doing.
- Jul 2003
- 58
December 18th, 2003 08:11 PM #3i dont flush engine and dont use oil additives as this can affect chemical composition of oil. Just use a good oil.
December 19th, 2003 08:52 AM #4
ok. whiz and oil additive.as for flushing naman before i drain ang oil nilalagay. sige, next time di nako mag fluflush at oil additives..
- 10,620
- Aug 2003
- 9,720
December 19th, 2003 12:01 PM #7there was an earlier thread on engine flush dito sa tsikot...lots of healthy info there
- 98
December 19th, 2003 04:21 PM #1018Dec2003 (UTC -8)
Don't use engine flushes or additives. At the worst case, its chemical composition will not be compatible with your engine, seals, and oil. At best case, its value is questionable.
Use your "savings" in buying the best oil you can afford instead.
For modern cars... people forget that coolants have a lifespan and that they need to be replaced. ...
