What is embedded in the key is one precision resistor. When you insert the key in the ignition, the resistor becomes part of a simple circuit involving 3 other resistors. If the key does not have a resistor or if the resistor has the wrong value, the circuit disables part of the car's electrical system to prevent the car from starting.
So why is this system using something as mundane as a single resistor rather than some sort of sophisticated embedded computer? There are probably two reasons: 1) manufacturing cost, and 2) reliability. The latter is probably a very big part of the equation. Think about everything a key goes through -- it's typically riding in a pocket full of coins, getting thrown on the table, opening bottles, and so on. Keys have to be remarkably durable, they have to last the life of the car, and they must always work. If a system that depends on a single resistor can do a good job, then that's a good system to use because there is less that can go wrong.
boybi, if your key (metal part) has two contact points... you can measure it by the use of precision tester using the resistance setting. if the resistance does not varies if you change the polarity of the wire probe, it is a resistor, otherwise it might composed of circuits...
:roll:
