Results 1 to 3 of 3
    Mga sir, any idea pano mapapaganda yung intak/exhaust manifold/pipe (not sure what is the correct term? kulay kalawang na kasi
    sandpaper and high temp paint ginamit ko sa akin so far ok naman
    Feb 2009
    Quote Originally Posted by CoolSwitch View Post
    coolswitch,
    the intake manifold is either made from aluminum, magnesium or polymer. the exhaust manifold is sometimes made of cast iron or steel tubes (headers). if they look rusted, you can use rust converter (the popular brand at the hardware stores is "turco". you brush this on or roller this liquid on and it converts rust into a substance that turns whitish. this effect is similar to your immunization shots, it retards further corrosion. then apply high temperature primer and high temperature paint
    jick
How to clean rusty pipes
