Results 1 to 15 of 15
    Jan 2003
    Guys, how do you properly check your engine's oil? I checked it kanina before I left house and konti na lang sya. When I arrived here sa work, after 4 hours na nakapatay, I checked it again and it was at normal level. Which one should I be making as a reference? Thanks
    overnight ba naka park yun car when you first checked it?
    Jan 2003
    Yes, sir. Bale, off ko sya ng 11:30 last night, then before going out at 2:30 kanina afternoon, I checked on it.
    check your dipstick at cold engine or before you start the engine, where the oils have rested on its oil pan.
  5. #5
    before i turn on the engine in the morning...i check..pag sa mga inlaws ko naman(inclined ang parking)i make adjustments..basta never check when the engine is running,while hot and after cranking..
    Jan 1970
    Quote Originally Posted by alwayz_yummy
    yup! natatawa na lang ako sa mga gas boys (at syempre dun na din sa mga drivers) when they check the oil while filling up, with the engine running pa! tapos sasabihin ng gas boy, sir mababa ung oil level o! si sir naman, bili agad ng oil.. hehehe
    so dapat reference is while engine is still cold?
    Aug 2004
    yes, bago start yung engine sa umaga check for the oil first.
    slip-slick, hahahaha.... oo nga napansin ko un sa mga gasoline station.
    Sa Isuzu casa (Manila) they check the dipstick after turning off the engine so when the engine is off it exceeds the max limit. This is the way to check daw when I talked to the Isuzu Engineer assigned sa casa. This is the same way they do also in Isuzu Pasig.
    Some Australian sites I've read before also check the oil after the engine is shut off.
    hmmm...
    i check mine after it has sat overnight... make sure the car is in level surface...
    Sep 2004
    lahat nang sinabi nila tama.
    i just take around 3 - 4 dips para sure ako sa level, and oil consistency.
    If you want to be sure, check it in the AM before start-up... then run the engine for 5 mins then check again (or when you get home at night).
    Jan 2003
    Thanks a lot sa mga input nyo guys. They were really a big help.
    Mar 2004
    sabi sa manual ko pwede nang checkin ang oil level 5 minutes after switching off the engine.
    hanggang saan ba sa dipstick ang level ng oil na pinakasafe sa engine :
    *tamang-tama lang sa max level
    *3/4 between min and max
    *1/2 between max and min
How to check Engine oil Properly?
