Results 1 to 10 of 15
- Jan 2003
- 41
January 7th, 2005 08:44 PM #1Guys, how do you properly check your engine's oil? I checked it kanina before I left house and konti na lang sya. When I arrived here sa work, after 4 hours na nakapatay, I checked it again and it was at normal level. Which one should I be making as a reference? Thanks
- 441
- Jan 2003
- 41
January 7th, 2005 08:59 PM #3Yes, sir. Bale, off ko sya ng 11:30 last night, then before going out at 2:30 kanina afternoon, I checked on it.
January 7th, 2005 09:23 PM #4
check your dipstick at cold engine or before you start the engine, where the oils have rested on its oil pan.
January 7th, 2005 10:13 PM #5
before i turn on the engine in the morning...i check..pag sa mga inlaws ko naman(inclined ang parking)i make adjustments..basta never check when the engine is running,while hot and after cranking..
- Jan 1970
- 396
January 9th, 2005 01:47 PM #6Originally Posted by alwayz_yummy
- Aug 2004
- 223
January 10th, 2005 03:27 AM #8yes, bago start yung engine sa umaga check for the oil first.
slip-slick, hahahaha.... oo nga napansin ko un sa mga gasoline station.
January 10th, 2005 11:00 PM #9
Sa Isuzu casa (Manila) they check the dipstick after turning off the engine so when the engine is off it exceeds the max limit. This is the way to check daw when I talked to the Isuzu Engineer assigned sa casa. This is the same way they do also in Isuzu Pasig.
January 19th, 2005 06:31 PM #10
Some Australian sites I've read before also check the oil after the engine is shut off.
