Quote Originally Posted by bluemeth View Post
Thanks kisshmet, dr. d and chris d!
*chris d, yes, inopen niya yung hood. Last PMS ko was June 2019. Medyo nagtataka rin ako why mababa yung coolant level. I heard na it's unusual. Will have it checked sa next PMS ko this Dec/Jan.
Meantime, ano pwede gamitin to top-up yung coolant reservoir? I know na Type II (blue) yung prescribed but medyo mahirap makahanap ng stock. Okay lang ba to mix yung existing na laman ng coolant reservoir with distilled water or other colors ng coolant na off-the-shelf from other stores?
Thanks again.
coolant levels do vary in the same car, depending on whether the engine is cold (early morning), hot (ordinary) or hotter (traffic, overheat).
check it early morning.
rule of thumb: if you can't find the correct coolant, go buy from the casa.
ok lang kung mahal. you'll probably use some of it only once, maybe twice in a year.
if you notice that you seem to be needing more coolant replenishment than above, your car might be overheating or has a leak.
