Page 1 of 2 12 LastLast
Results 1 to 20 of 31
    Feb 2010
    Last sat, nag pa pms ako ng crv for 2 yrs/40k mileage ko is 26k. We have been using 5W-30 oil and nag 0W-20 ako, may problema ba dun? wala naman? wala naman ako napapansin, pero meron ba dito pwede magpaliwanag kung ano pinagkaiba nung dalawa. sabi nung sa, semi daw yung 5W-30 and Full daw 0W-20...pero alam ko Fully Synthetic talaga ginamit namin after a year so nagtaka ako bat ganun sinabi nya....
    help naman...
    ito na ata ang default fully synth motor oil ng honda ngayon. parang ang nipis masyado kaya palagay ko hindi ko na ilalagay sa '06 fd namin baka 'di kayanin ng seals nun
    btw, bs lang iyong sinabi ng SA. gusto niya lang siguro i-push iyong 0w-20 langis na ito
    Dec 2009
    If you want to prolong your engine
    and give it the maximum protection you should, and you don't need fuel efficiency, this is the ideal oil weight for a gasoline engine.
    0W-40
    5W-40
    10W-40
    the lower the second number, the greater chance that the oil will shear faster providing less lubrication.
    Oct 2011
    Quote Originally Posted by slvrsrfr2301 View Post
    help naman...
    masyado mababa ung operating temp ng oil viscosity mo lalo na 40k mileage ka na imo.
    - - - Updated - - -
    Quote Originally Posted by miko101130 View Post
    0W-40
    5W-40
    10W-40
    Sir miko, what will then be the proper oil viscosity if fuel efficiency ang habol ko?
    yan na kasi yun oil nila for the new models, kaya wala na sila nun 5W-40 na fully synt...
    Dec 2009
    Sir retz if gas engine ka tapos primary factor mo is fuel efficiency, the 0W-30 or the 0W-20 would give you the best mileage...
    pag sa diesel engine ginamit yung weight na yan for sure taas sobra ng wear rates and definitely sira turbocharger and engine after sometime...
    honda might be advocating that wieght of oil para ma-achieve nila yung promised fuel efficiency ratings nila sa models nila...
    fuel efficiency achieved through the use of those weights would at the very best and perfect conditions give you just around 1k/L advantage.....
    Jan 2012
    0W-40
    5W-40
    10W-40
    Idol, may nagsabi sakin yung Flash point daw yung nagdedetermine kung kagad nag shi-shear yung oil. Is this true?
    Thanks.
    Feb 2010
    update, sa fc may improvement, from 8.4km/l 8.5km/l n sya ngayon, sa gas, di ko masabi if matakaw since 95 muna dahil sa tagaytay pa ko nagkakarga ng 97...update ko pag nakapag 97 na ko
    Dec 2009
    Quote Originally Posted by bayen View Post
    Thanks.
    Bro, flash point is "the temperature at which the oil will start to ignite (oil will catch fire)".... its different from shear stability... so hindi totoo yung nagsabi sayo nun sir bayen,, hehehehe...
    "Oil experiences very high stresses in certain areas of the engine such as in the oil pump, cam shaft area , piston rings, and any other areas where two mating surface areas squeeze the oil film out momentarily"
    "Most multigrade engine oils contain special types of additives, called Viscosity Index Improvers, which are composed of very large, viscosity-controlling molecules. As the oil passes through the engine, these molecules are permanently sheared or torn apart over time, causing the additive to lose its viscosity-contributing advantages which reduces the oils ability to maintain its higher number"
    "You might recall that multi-viscosity petroleum oils tend to use long chain polymers to "beef" themselves up. Under high stress conditions where shearing can occur, these polymers break down."
    pag hindi "fully synthetic ang oil, it is prone to shearing (napupunit temporary yung lubrication)....
    in the case ng honda na Fully synthetic, it could withstand shearing forces up to a point.... though weight 20 o 30 yung oil dahil sa uniform ang molecules it could provide protection.."(we are talking og gas engines here)",, hindi uubra yan sa diesels...
    Dec 2007
    Chances are, you're not going to stress your engine hard enough for the low viscosity to matter.
    Low viscosity = less internal drag = better fuel economy.
    Unless you're winding the engine to its redline a lot, 0W-20 should be fine.
    Feb 2010
    Quote Originally Posted by Type 100 View Post
    pero di problema kahit may monthly hataw to the max?
    20 or even 30 weight oil is very thin. They are fine basta nasa normal operating temperature ang engine, pero kawawa ang engine pag nagka problem sa cooling system/nag over heat ung kotse.
    Bagay lang to sa brand new or cars na walang history ng overheat.
    Jun 2005
    my new toyota uses 0w-20. according to my mechanic 0w-20 is strictly for new engines and highly recommend i switch to 5w-30 after about 20k miles no matter what casa says. ill stick to what factory uses (not necessarily what casa suggests). id like to hear tsikot experts take on this.
    Hate to revive this thread but here goes...
    Just had my 10K PMS at Honda SPA and they used this oil on our 2012 Jazz. I'm a little skeptical and uneasy with this as it might cause some damage to the engine since it's too thin as some would say? But would Honda put something that could harm my car? It's still under warranty so I guess it helps reduce my uneasiness. I drive our Jazz approximately 60-80 Kms everyday so it really worries me that I may prematurely wear out or damage my engine.
    Hope you can share some insights.
    THANKS!
    Dec 2002
    nagulat nga ako kanina bakit iba yung binigay na bote, akala ko ibang design lang ng LEV nila.
    Kakachange oil ko lang sana maganda response at tumagal.
    Aug 2012
    Quote Originally Posted by Bry028 View Post
    THANKS!
    idol kamusta na jazz mo? yun padin ba ginagamit mong engine oil?
    THANKS!
    May 2011
    THANKS!
    How many liters ang nilagay? Saka magkano inabot?
    Jul 2010
    kamusata po ang 0w20.
    Mar 2018
    0W-40
    5W-40
    10W-40
    True.
    Dec 2009
    ^Eh paano kung wala ng 40 sa market kasi sobrang laos na?
    Sent from my SM-G355H using Tapatalk
Honda Eco Premium Oil 0W-20 (Fully Synthetic)
