Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Feb 2007
    Hi,
    Toyota Innova 2012 G VVTi Gas, Brand new, 800km odometer. This topic should be applicable to any car too.
    Need your advise please.
    What are the important points to consider before leaving the car unused for a very long time, say 12 months. And nobody will be able to start the engine periodically. It will be totatlly unused.
    Here are a couple of points I thought but they may be wrong too. Please add your inputs or comments.
    Prior to leaving the car unused:
    (On appearance)
    - Make sure you cover the entire car using a Car Cover to protect against heavy dust, sun, and rain
    - Inside the vehicle, use a moisture and odor absorber by putting lots of silica gel and charcoal
    ? What else?
    (On Tire)
    ? It will definitely deflate over the 12 month period and there is a risk that the tire's shape will get oblong. What to do?
    (On Engine and Lubricants)
    ? What to do about the engine oil..should we drain it or leave it as is?
    ? What to do about other fluids like brake, steering, gear, windshield washer, etc? Drain them or leave them as is?
    (On Battery)
    ? Disconnect the Battery or not? If we disconnect, then keyless entry will not work and we will have to manually open it using a key. I guess this will be a personal choice. But any implications of disconnecting it or not?
    Things to do when you want to use the car again after the long period:
    (On appearance)
    - Maybe get an interior detailing service or clean it thorughly yourself
    ? Do we have to replace the engine oil and other lubricants first?
    (On Tire)
    ? Can we still use the same tire safely?
    And a general question: Will there be negative effects to the engine even after following the preparations above after leaving the car unused for many months?
    Feb 2012
    things i gave thought over din before i left for a month. buti was able to park my car sa di naarawan. tapos, just inflated my tires to around 40 para nga ma-minimize pagka-oblong. didn't disconnect the battery na rin coz of the keyless entry nga. parang me nabasa akong effect daw pag nawalan ng supply ang alarm. when i arrived though, me karga pa naman battery pero can't crank the engine na. so i just used a jumper cable sa kabilang kotse. but mine is one month nga lang, so will be waiting for inputs too from the masters here for the TS's case..
    Feb 2007
    Quote Originally Posted by gearhead000 View Post
    I had one experience in another car of mine. i left it unused for about two months. I did not take any measures at that time. When I came back, the interior of the car had presence of molds and had odor. It was rainy season back then. So that's why I posted above that maybe the learning is to ensure that I put a lot of silica gel and charcoal. Battery got drained too as I didnt disconnect it prior to leaving the car unused. But maybe because my alram system was kinda faulty...
    Any other thoughts guys?
    I work abroad for 4-6months at a time and my car almost sits that long also. It only gets used twice a month by my wife, kahapon she told me na nag dedeflate daw yung isang tire and when she had it checked ok naman yung valve at walang leak so i'm guessing na nag oblong na yung gulong.
    So my question is, pag nag oblong ba babalik pa sa original shape if ma gamit na ulit?
    Feb 2009
    Quote Originally Posted by laserbim View Post
    Hi,
    (On appearance)
    ? What else?
    (On Tire)
    (On Battery)
    (On appearance)
    (On Tire)
    this procedure is called "pickling the car". from ground up:
    for extended period of time:
    reduce the tire pressure and protect from UV rays
    raise the vehicle and support with jackstands to unload the suspension
    from under the hood,
    a. change the engine oil and filter and let oil circulate until warm
    b. change the brake fluid and cover the master cylinder air tight (toyota master cylinders are vented allowing moisture to seep into it)
    c. check the protection level of the anti freeze/coolant, if okay, retain
    d. check the transmission fluid
    e. lubricate hood hinges, hood latch and cable, lubricate transmission linkages
    f. protect the battery terminals and battery cable clamps with vaseline to avoid corrosion
    g. if leaving the battery connected, install a battery trickle charger, if not, disconnect battery
    h. use animal repellent under the hood and around the fuel tank area
    the fuel system:
    leave at least half tank of fuel and add fuel stabilizer
    the exhaust system:
    block the exhaust tail pipe with steel wool to prevent mud bees, small insects and rodents from housing inside
    the car's body:
    lubricate door hinges( with vaseline) and locks(with spray oil), lubricate fuel door hinge
    protect the interior by blocking sunlight into the upholstery and dash
    protect the exterior with breathable fabric car cover and further cover with non permeable sheet (polyethylene plastic)
    and last but not the least, protect car from vandalism and theft in a secure, weather resistant enclosure.
    Oct 2009
    ingat nalang din sa carnapfer
    yan ang pinaka importante he he he..:D
    Mar 2012
    Elevate the vehicle off the ground using jack stands.
    Dec 2003
    Unused for 12 months? Sell it. Invest the money on something low risk. Buy a new car upon return. Least amount of headaches.
    Sep 2005
    i agree with this..
    Quote Originally Posted by RustyXIII View Post
    Feb 2007
    i agree with this..
    I actually want to sell it sana at eto ang pinakamaganda na option. The problem is that the car is under bank loan. Not sure how I can sell it in this situation. I don't have cash naman to pay off entire amount. Is there a way to sell it if it is currently under bank finance?
    Isa pang kalaban ang mga daga.
    Have you inquired with facilities like Alex Car Storage?
    Have no idea on the price though.
    Car Storage by Alex Restoration
    Jan 2008
    You can sell it. With the buyer assuming the balance of the loan.
    Feb 2007
    Quote Originally Posted by Errol5 View Post
    Assume balance....my name would still be the one in the bank contract, right? so that means i am still liable. if the buyer default in payment, it is my record that will be compromised.
    Or is there a legal process/document that can be followed to ensure that i am completely not liable even though my name is in the contract?
    Jan 2008
    If you found yourself a deal regarding the sale of your car, have it done sa bank where you secured your car loan, they will know what to do.
    Our experience with assuming the balance of a car, the seller pulled out his PDCs (post-dated check) from the bank and replaced it with our check (us personally handing it over to a bank/loan representative), with it also is the deed of sale. Kaya if ever may sumablay na monthly payment, yun naka pangalan na sa new checks ang mananagot.
    The seller also provided us with an Authorization letter and Special Power of Atty (granting us power to secure the documents with regards to the car after finishing the loan).
    But this was 4 years ago, ewan ko kung same pa rin ang process. Different banks do different things.
    Feb 2007
    Was the bank contract revised to reflect your name instead of the seller? Or was a new contract created and then the old one voided?
    Best thing to do is have your prospective buyer to secure a new loan from whatever banks then use that proceed pay off your loan... So wala ka na pakialam Sa carbloan niya... Sahil settle na yun loan mo Sa bank mo.
    Wala pakialam bank Sa buyer mo kahit meron kayong side contract na assume balance siya, ikaw kausap ng bank at hinde siya, they wil also not allow replacing your PDC cheques to that of your buyer.
    Jan 2008
    Last time we did it, they allowed replacing the checks.
    The bank would rather have somebody else continue the loan than confiscating the car.
    What bank? How will the bank allow it w/o knowing the credit standing of the buyer? that's against all the policy...
    They probably allowed it but loan is still under the original applicant... So whaever happen to the loan the original party will and still answersle to the bank...
    Jan 2009
    OT: I can't seem to understand why you had to buy the car prior to leaving the country for a year? You could've just bought it after you came back and saved the car from a year's worth of devaulation.
    BTT: Don't forget to lubricate the window channels and weather strips with silicone spray or grease. A light coat should be enough to prevent the windows and doors from sticking.
    Feb 2007
    Thanks for the good to oj88.
    On why I bought the car...let us say, something unexpected or some opportunity came that I did not know at the time I bought the car
Checklist: if your car will not be used for a long period (months)
