Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
    Lahat ng PMS ko sa Ertiga ko laging may nakalistang drain plug washer sa 3 different casa, 26 pesos. Ngayong natapos na ang warranty, bumili ako sa casa ng OEM oil filters para ipagawa ko sa labas, nagtaka ako di na raw kailangan yung washer. Malamang di nga nila ito pinapalitan.
    Sent from my ASUS_Z017DA using Tapatalk
    Apr 2009
    that is what most uncaring mechanics say because they just want to earn money. The crush gasket is there for a purpose. to protect the bolt from becoming round headed and to prevent the threaded part of the drain pan to become loose thread.
    I mean binili ko ito sa parts manager, and I specified this part, and said no need na daw. Instead he's convincing me to have my PMS to them with a discount.
    Crush gaskets are meant to be replaced every change oil except those nitrile rubber types which can be re-used.
    Re-using could cause scoring/pitting of the plug surface and later cause leaks.
    when we were young and poor-ish, we used to re-use these gaskets. ok naman. walang tulo. binibili yan noon.
    ... lucky?
    They are cheap
    our re-used ones came free.
    peace, brother.
    Quote Originally Posted by LN106G View Post
    If that's the case we can always use the teflon tape.
    But I remember my old 97 FX diesel has never use gasket or teflon tape on every change oil routine in my favorite gasoline service station, and never has an issue of leak or rounded drain plug until I sold it 1n 2015.
    Jan 2008
    Dont use teflon.. if crush washers are not available, copper washers can also be used as alternative.. relatively easy to find and cheap too
Hirap tanggalin ng drain plug
