Results 1 to 7 of 7
- May 2008
- 2
June 25th, 2009 12:28 PM #1Tanong ko lang po. Bigla pong parang naging hirap ung makina ng revo ko pag tapos ko mag pa change oil. bumigat ung manibela tapos tagal mag shift ng AT. di ako sure kung anong oil ginamit kasi tatay ko ang nag pa change oil. ano po maganda gawin? mali po ba ang oil na nagamit?
thanks in advance.
June 25th, 2009 04:09 PM #2
i doubt its with the oil. were the spark plugs replaced too? how bout the fuel filter?
yung sa pamimigat ng manibela, walang connection yun sa change oil. check mo muna yung inflation pressure ng tires mo and yung alignment ng tires.
June 26th, 2009 03:39 PM #3
hindi kaya bumaba idling kaya bumigat ung steering wheel? ganyan akin dati. baka naman nasobrahan ng langis? hindi ako sigurado pero alam ko nakakasama dahil tumatapon sa plugs ung langis. correct me if im wrong hehe
June 26th, 2009 06:15 PM #4
Have the engine checked again. Maybe the sparkplug gapping is wrong or something else is "off". Have the service station check the ignition timing as well and the condition of the air filter too.
Also check what oil was used. It might be a grade heavier than the normal grade used for your engine.
- May 2008
- 2
June 28th, 2009 09:19 PM #5*1D4LVakala ko nga din kaya mabigat manibela kasi sa gulong kasi medyo pag binibitawan ko manibela kumakabig pa kaliwa so pina bomba ko pero ganun padin.
nde napalitan ung spark plug oil filter lang tska oil. ayaw umamin ng tatay ko ano ginawa nya eh at kung ano langis ginamit nya bkakc mapagalitan ko. lol.
thanks po mga sir sa opinions. baka pa check ko nlng po pag may time ako tska budget.
isa pa pala medyo lumakas ung gas consumption dahil nga sa humina ang hatak medyo kelangan tapakan talaga ung gas bago humatak sha. tsk tsk tsk. nag taas pa naman gas ngaun. nanaman!
thanks po ulit.
June 29th, 2009 01:02 PM #6
June 29th, 2009 03:04 PM #7
first things first tanugin mo muna tatay mo kung anong langis ang ginamit..baka pang diesel
Daming issue ng SU7:grin:
Xiaomi E-Car
