Results 1 to 13 of 13
    Quote Originally Posted by darkside_1975 View Post
    help mga bro my sons corolla matic gli 95 has thick white smoke comming out of the tailpipe no overheat sya maganda naman ang hatak yun lang biglang umusok ng puti pag mainit na ang makina at first pag bagong start walang usok pag uminit na ayan na parat 2 stroke na tricycle at masakit sa ilong at mata ang usok ano kaya ang nagyayari pa help naman mga sir taga las pinas kami thanks in advance
    There would be an oil leak somewhere inside the engine's cylinders. It will require either a top overhaul or full overhaul to fix the problem depending on where the leak will be found.
    Jan 2008
    thanks for the reply bro ghosthunter
    most probably your engine is burning coolant. nagbabawas ba ang tubig sa radiator and coolant bottle?
    could be that there is a head gasket leak, wherein coolant or water is being burned.
    ang alam ko pag black, its oil.
    Jan 2008
    di ko pa ngacheck bro anak ko kasi gumagamit and 3 kms lang ang school nya sa place namin sana nga cylinder head lang thanks sa reply mga sir nagtext sakin anak ko pinatignan daw nya sa pyesa valve seal and head gasket tapos 3.5k labor ok na kaya yun mga sir? im also contemplating on swapping this gli for a subaru legacy 96 mdl willing owner na i shoulder ang cost ng repair ng gli but having second thoughts since hindi ako familiar with subaru and lost cr sya xerox lang and orig or , affidavit of loss and deed of sale and secretary certificate ang problem lang is dun sa xerox ng CR kulang ng isang digit baka lalong lumaki ang problema ko what do you thing should i swap my gli to the subaru or pagawa ko nalang ok ang takbo ng legacy kaso medyo maingay ang makina na ang sabi ng owner is common daw yun sa boxer engine pasensya na mga bro daming tanong he he drivesafe
    yung subaru legacy... although mas ok sya imho, parang madaming problem sa papeles. and besides, madami ka na ring ipapagawa dyan dahil willing sya i-swap and ipagawa yung oto mo eh, which makes it more suspicious.... pagawa mo na lang yung corolla.
    Jan 2008
    mukhang tama ka brod 1D4LV pagawa ko nalang corolla thanks uli sa replys nyo mga tol drivesafe
help thick white smoke comming out of the tailpipe
