Results 1 to 7 of 7
- Oct 2009
- 179
April 13th, 2017 01:15 PM #1Sirs ask ko lang ano kayang problem kapag my lumalabas na water sa kinakabitan ng intake manifold at cylinderhead? nahihirapan kasi umistart un sasakyan nauubusan ng fuel sa filter pero ok namam pump. eto ba effect kapag my leak sa intake manifold? Thanks.
Sent from my SM-J700H using Tsikot Forums mobile app
- May 2011
- 481
April 13th, 2017 01:21 PM #2What is your make, model year, model, and mileage if your car? Tanong sa hangin suntok sa buwan ang sagot
- 54,281
- Mar 2013
- 220
April 13th, 2017 07:39 PM #4Natawa ako sir, tama ka nga hehe
BAKA naman need mo lang palitan fuel hose line mo dahil maycrack na siya better check din sir ng hose clamp. Kung walang crack cut mo ung dulo at ikabit mo uli at reclamp mo na lang, yan ay kung aabot ung hose sir. Konting alam ko lang pagwala sa tamang pressure ang fuel rail dahil mayleak hindi ganun kaganda ang buga ng injectors kaya hirap ka magstart. Tingin ko lang hehe
- Oct 2009
- 179
April 15th, 2017 08:25 PM #5Carb engine sirs. Its an old 3 cylinder suzuki fronte/alto. Binaklas ko na intake manifold kasi visible un tubig na lumalabas sa pagitan ng intake at head baka gasket kasi. Ano pa kaya dahilan bakit my tubig na lumalabas sa intake?
April 15th, 2017 08:42 PM #6
is your coolant just water?
- Mar 2013
- 220
April 16th, 2017 06:59 AM #7Ah ok tubig pla not fuel (bilis ng basa ko hehe), maywater port ang intake manifold at cylinderhhead magkatapat un to bring down temp ng air/fuel mixture para masmaganda ang combustion. Hirap ka nga magstart nyan at medyo rough idle minsan dahil singaw manifold more air than fuel(masama ang timpla hehe). Replace intake manifold gasket (super clean both surface para lapat!) at pantay lang paghigpit ng bolts n nuts ( if you have torque wrench much better).
Kung sirain mga modern releases nila, edi walang pinagkaiba sa ford.
China cars
