Page 1 of 3 123 LastLast
Results 1 to 10 of 25
    Mar 2011
    question po, kanina nag pa gas ako, (toyota corolla) napasin ko diesel ang kinarga buti 13 pesos pa lang 0.29li. kinausap ko supervisor, mahahalo lang daw yun matutunaw daw sa gasoline yun kasi sobrang konte lang. medyo nagmamadali din ako kaya hindi ko na pina drain. sabi naman nya pag nagkaproblem within the day ibalik ko daw. nakauwi naman ako ng maayos. anyway ok lang kaya yun? or may long term effect pa yun? need ko ba stay on yung engine ko para makita ko kung mamatay or ok na yun?
    thanks!
    yup, it's the other way around Ang mas sakit Sa ulo...diesel engine nakargshsn ng gas..wait didi get it right or Ito yun mas masama
    Oct 2011
    Ano ang level ng fuel tank mo before the refill ?
    Mar 2011
    below 1/4 sir pero wala pa red warning, konteng konteng below 1/4 level tapos nagpakarga ko ng 300.
    May 2009
    Diesel's specific gravity is 0.82 to 0.95. Gasoline's specific gravity is 0.71–0.77. Basing from the SG, diesel stays at the bottom. Gas on top. Correct me if i'm wrong but the two are miscible.
    Octane rating is lowered so there is a possibility of knocking.
    Volatility is also lowered. Fuel will not vaporize easily.
    Diesel in a Gas engine is actually not bad when done in a small ratio but straight Diesel will not burn properly in a Gas engine. but it still depends on the ratio of diesel to gas. ilan liters ba gasoline pinakarga mo tsaka carbureted ba or fuel injected tsikot mo?
    Oct 2011
    hindi ba mas malaki ang nozzle ng diesel at ito ay hindi kasya sa opening ng gas tank?
    Mar 2011
    Quote Originally Posted by miked View Post
    fuel injected sir. corolla gli. 1/4 laman ng tank, tapos nalagyan ng 0.29 li na diesel nagpakarga ko ng 6li gas.
    Mar 2011
    same lang yata dito sa pilipinas sir. dapat talaga iba iba nozzle para hindi na magkamali.
    Tama ka riyan bro.,- diesel sa gas na sasakyan,- the worst thing that could happen ay itirik ka lang... and then, i-drain mo ang buong tangke... Pero, gas sa diesel na sasakyan,- puwedeng sirain ang walls ng makina mo. Remember,- walang spark plugs ang diesel na makina,- kaya pressure at temperature ang pang-ignite ng fuel...- kaya dapat- i-drain kaagad....
    Sa ibang bansa iyan, katulad ng Amerika bro.,- hindi rito sa Pilipinas....
    15.2K:froggy:
    Oct 2011
    15.2K:froggy:
    sana gawin na rin standard yan sa pinas.
diesel namix sa gasoline, any problem?
