Results 1 to 12 of 12
    i recently got a toyota corolla gli 95 automatic, engine, works fine while running, problem is when im on "D" and brakes pag traffic, the engine vibrates medyo "mayanig" kaya nilalagay ko na lang sa "N" para mawala, ive notice pag naka off ang aircon ko , di nagvivibrate engine ko. pls advise mga sir,nagpachange oil and atf nako and also the spark plugs, is this normal kasi new A/t user ako, or should i get this fix?
    Apr 2010
    sir pareho tayo, i have vios 2003. sino kaya makakatulong sa tin.
    Feb 2006
    i have the same problem sa 95 honda esi a/t ko. kapag matagal na takbuhan and then idle on "D4/D3/ or R" magvvibrate then mamamatay engine. some said its engine support.
    mga gurus, any thoughts po? TIA!
    Dec 2009
    busted engine and/or tranny support na
    Jul 2010
    try checking first kung servo (or idle up) is working properly, kung ok naman, have a look on the engine/tranny support.
    Aug 2010
    good day, ganyan problema ko, marami din pala tayo nakaka-experience nyan, but i resolved by adjusting the idle speed (gas and air fuel mixture, carburated pa kasi gamit ko e) to a higher level, sinakto ko ng 1rpm dati 800rpm, ngaun ok na, then sabi ng friend ko tune-up daw, palit ng spark plugs para mapababa ulit ung menor, pero sa tignin ko mataas talaga dapat ang idle speed ng mga matic na auto, karamihan ng kilala kong naka matic ang mataas ang idle speed nila talaga.
help..pag naka "d" + brakes and my aircon is on, engine vibrates
