Page 1 of 2 12 LastLast
Results 1 to 20 of 30
    Sep 2008
    assembled lang po sasakyan namin, medyo matanda na din po. mausok na po at 2 beses na po ako nahuli sa makati. ginawa ko na po lahat ng alam ko, nagpalit na ako ng nozzles at ngpacalibrate na ko. nilinis ko na din po ung exhaust. sana may makatulong lang po.
    Sep 2006
    Kung sigurado ka sa condition ng engine mo, try mo ito:
    Check valve clearance, baka tukod.
    Check injection pump to engine timing.
    Check injection pump diaphragm, baka butas.
    Black or white smoke?
    Umuusok lang ba pag malamig pa ang makina, or kung mainit din?
    Hard starting ba?
    Sana naman tinulungan ka nung workshop na nagcalibrate ng pump and injectors mo.
    Sep 2008
    hindi naman hard starting. hindi mausok pag nka-idle pero pag medyo mataas na ung rpm saka umuusok at pagbitaw ng silinyador. black smoke yung lumalabas eh.
    Aug 2004
    That's running rich or you've got a ton of carbon in the combustion chambers... agree... check the valves and the pump...
    Sep 2008
    meron ba kayong marerefer sakin na pwede kong mapagpagawaan ko? im in muntinlupa area.
    Aug 2004
    I don't know any diesel specialists in that area... backyard mechanic lang ang pinupuntahan ko sa Laguna area...
    Sep 2008
    does this mean ngo-over deliver ung IP ko? and do you think i have to change my piston rings even if hindi naman ngcoconsume ng oil?
    Sep 2006
    does this mean nago-over deliver ung IP ko? Parang ganoon na nga. Baka hindi tama ang previous calibrate ng IP.
    and do you think i have to change my piston rings even if hindi naman ngcoconsume ng oil? Hindi kailangan sa ngayon. Mukhang normal pa naman ang compression ng engine dahil madali mag start.
    Best procedure:
    1. Hanap ka good mechanic
    2. Check valve clearance
    3. Check injection pump timing
    4. Run the engine without the exhaust pipe/muffler. Kung misan, barado lang ito at puno ng carbon.
    5. Recalibrate injection pump
    Good luck!!!
    Dec 2009
    Sir, yung AUV (C240) ko po eh naglalabas ng maraming white smoke pag average revs..pero pag masyado na pong mataas katulad pag na sa highway na eh napakaitim na po..kaya limitado lang yung tapak ko kasi kinokontrol ko lagi yung buga ng usok ko tuwing nagddrive..
    Additional question din po, plano ko po kasi sanang palitan yung C240 ko ng 4JB1T from isuzuphil kaso sa research ko po masyado pong mahal..pwede ko nalang po ba na palitan ang injection pump ko? from Indirect to DI? at pwede rin po ba na palagyan po ng turbo yung C240 q? natatakot lang kasi ako baka bumigay na yung cylinders..meron po ba yung isuzuphil ng mga ganitong parts?
    Salamat po ng marami! Pasenxa na sa abala...
    Oct 2009
    Quote Originally Posted by Jasper Hermano View Post
    Basta white smoke nagsusunog ka na ng oil nun. Piston rings na papalitan pag ganun. Ang rings kase ang naghihiwalay ng engine oil mo (sa baba ng piston) at fuel/air mixture mo (sa taas ng piston). Pag gastado na humahalo na ang oil sa pag ignite ng fuel mo. Pero to be sure pa compression test mo. Nawawalan ka na ba ng hatak?
    Sa ibang tanong mo wala po akong alam sa diesel engines sensya na.
    Dec 2009
    Quote Originally Posted by Tincan View Post
    Sir tincan,
    pwede rin po..lumang luma na rin ho kasi ang makina..mejo nga po ramdam ko na bumaba hatak..at parang nanginginig ng konti yung takbo nia..
    salamat po sa recommendation..at least alam ko na po kung ano mga ippcheck ko..
    Dec 2009
    Mga sir,
    ano naman po kaya dapat kong gawin para pwede ko nang pa lagyan ng turbo ang isuzu c240? Nakakatamad po kasing palagyan ng bagong mountings kung papalitan ko makina eh..
    Salamat po..
    Sir jasper palinis mo muna yung exhaust pipe mo, looks like d mo sya na rerev ng mataas lagi kya marami na carbon deposits given the black smoke. or better lagyan mo ng hose ng tubig yung muffler then water it up, pag puno na pull it out then rev-it para mawala yung deposits. Pag na baby kc ang engine d nakakalabas yung carbon, kaya ako pag nasa NLEX try ko sagad to take out the carbon.
    pag ganun pa rin check mo yung airfilter, baka barado kaya hindi maganda yung air-fuel ratio mo. I think pag black smoke, sign din yun ng un-burnt fuel. Too much diesel not enough air. Pag ok yung airfilter... yun lang baka for calibration ka na...
    Sep 2006
    Sir, yung AUV (C240) ko po eh naglalabas ng maraming white smoke pag average revs..pero pag masyado na pong mataas katulad pag na sa highway na eh napakaitim na po..kaya limitado lang yung tapak ko kasi kinokontrol ko lagi yung buga ng usok ko tuwing nagddrive.. Paano ito nagsimula at kelan? Meroon bang gumalaw ng injection system mo bago ito nangyari?
    Additional question din po, plano ko po kasi sanang palitan yung C240 ko ng 4JB1T from isuzuphil kaso sa research ko po masyado pong mahal..pwede ko nalang po ba na palitan ang injection pump ko? from Indirect to DI? Pwede ito ma-convert. Pero may kamahalan sa gastos, chaka hindi rin tayo sigurado kung maganda ang magiging resulta.
    at pwede rin po ba na palagyan po ng turbo yung C240 q? Hindi ito pwede dahil vacuum controlled ang original injection pump ng C240.
    natatakot lang kasi ako baka bumigay na yung cylinders..meron po ba yung isuzuphil ng mga ganitong parts? Isuzu lang ang makakasagot sa tanong mo.
    Salamat po ng marami! Pasenxa na sa abala... Walang ano man.
    Dec 2009
    Quote Originally Posted by Dieseldude View Post
    5 years na pong hindi nagagalaw yung fuel injection pump..ang alam ko lang po may tagas po sia..ndi naman po ganun ka lakasan..pero lagi po xang basa ng diesel..
    Salamat po talaga..
    Dec 2009
    Sir blue_gambit..
    Salamat po talaga..I'll do as you say..may valve po yung sa may exhaust pipe malapit sa makina..para po dun lagyan ng tubig..
    At saka, mejo maalaga nga po ako sa makina..sa lahat ng sasakyan namin..2-3k rpm (for diesel engines, kasi ginagamit ko husto yung torque nia) lang ako madalas pag below 4th gear..
    yung air filter nga po pala, may mairerekumenda po ba kaung brand na pwede kong ipalit sa air filter ng c240? parang graba lang po kasi ata ang masasala ng filter ko eh..nung nilinis ko siya..
    Salamat po talaga!
    Mar 2011
    Good morning mga ka-tsikot, ask ko lang ano kaya problem nung c240 namin kasi newly overhauled na yung engine tapos sumuka ng oil sa exhaust.
    Pinalitan po namin ulit valve seal pero parang ganun pa din. Ano po kaya problem nito?
    Dear Jasper:
    Whether a diesel engine is a direct injection (DI) design or indirect injection (IDI) design is NOT determined by the injection pump, it is determined by the location and design of the COMBUSTION CHAMBER.
    In a DIRECT INJECTION diesel, the combustion chamber is INSIDE the crown of the piston and the injector sprays fuel directly into this bowl.
    All combustion occurs inside this bowl and combustion pressure acts directly on the piston with little loss of heat and pressure to the other parts of the engine, making this thermodynamically the most efficient design.
    In an INDIRECT INJECTION diesel, the combustion chamber is DIVIDED - separated into several parts, which are interconnected by narrow passages.
    In this design, the injector sprays into the main chamber which is usually located within the cylinder head, with a narrow passage, called a 'throat' connecting it to the cylinder and piston.
    The reason for this configuration is to generate turbulence - rapid movement of air, to ensure good mixing with the fuel spray and efficient, quick and complete combustion.
    Of course the narrow passages, extended surface areas and separated combustion zones, create greater heat and throttling losses, lowering the designs' thermodynamic efficiency.
    So, why go to all this trouble?
    Well IDI diesels were first successful High-Speed diesel designs.
    They were developed before World War 2 in an effort to make AUTOMOTIVE (car and light truck) diesel engines run at higher RPM's.
    The earliest and most large diesel engines (power plant, ship, locomotive) were all Direct Injection designs - they could use this design because they ran slowly.
    As engineers tried to speed up diesel engines, they found that it was very difficult to make the fuel burn fast enough with the D.I. design.
    They realized that the problem was that the air and fuel were not mixing fast enough to keep up with the high speed in the DI design.
    Their answer was to force the air at high speed through narrow passages into a separate chamber where it would meet the injection spray, mix violently with it, then burn, reversing it's flow and exiting the opposite way it came in.
    Numerous designs were created by various companies:
    1) the Turbulence Chamber (favored by the Japanese, the British and the French carmakers, VW, Ricardo and Kloeckner-Humboldt-Deutz),
    2) the Pre-Combustion Chamber (favored by Daimler-Benz and Caterpillar),
    3) the Energy Cell (favored by Lanova),
    just to name a few, used different variations of the aforementioned theme to achieve the desired results.
    Locally, one of the most common cars to use this design (Ricardo Comet V Turbulence Chamber) was the Isuzu Gemini Diesel with it's 4FB1 engine - a landmark in low-cost automotive diesels.
    These designs reached their peak of popularity from the 1980's to the mid 1990's.
    They were later replaced by turbo-DI designs, which have become almost universal among automotive diesels.
    So how did modern engineer's overcome the problem of fast combustion with the DI design?
    It all comes down to the problem of MIXING of the air and fuel.
    In the IDI designs, AIR is sped up to force good mixing with the relatively low-pressure injection spray.
    In MODERN DI designs, FUEL is sped up to create the necessary good mixing - using very high pressure sprays.
    That is how we were able to make the DI diesel design work at high speed.
    The key that enables the modern CRDi diesel is the high-pressure, electronically-controlled injection pump and it's fast-acting injectors.
    Best Regards,
    Dusky Lim
    Feb 2009
    Quote Originally Posted by c240 View Post
    c240,
    have your engine compression checked, regardless how tuned or new your fuel injection system is, if the compression is poor, the fuel does not get completely burnt. this can be obtained using the glow plug holes. compare each cylinder readings. also, check that the intake is not restricted of soot and dust or the engine is suffocating. the efficiency of your combustion can be read with a pyrometer at each outlet port of the exhaust manifold. a stroboscopic timing light can be used to set injection timing using the #1 glow plug hole with a timng light adaptor if available or another way of making sure of the ijnection timing is by using a transducer designed to be clipped on to the #1 injection tube and adapted to a stroboscopic timing light ( if available, but doubt shops in metro manila have this).check what you can, start with air induction, compression then the injection static timing
    jick
    Feb 2009
    c240,
    your engine fuel injection system comes in two slightly different versions; 1-mechanical (centrifugal) governor, 2-pneumatic governor. the latter has a diaphragm in a chamber in line with the fuel control rack, check this diaphragm for rips, tears or cuts and also for flexibility
    jick
help naman po with my isuzu c240
