Results 11 to 20 of 33
January 16th, 2008 03:02 PM #11
bro, try mo iopen yung oil cap, slowly lang, then pag completely open na, try to feel kung hinihigop pabalik yung cap.
an engine with good compression should suck it up like a vacuum. pag hindi na humihigop, wala ng back pressure, ibig sabihin blowby na kaya laging tagas oil. it also means the one who worked on your piston messed it up.
do the above when the engine is warm already
January 17th, 2008 01:18 AM #12
Thank You Asus700.... I'll do that then. Pag hindi na nga sya humihigop, ano po problem nya? ano po remedyo dun?
January 17th, 2008 01:51 AM #13
pa compression test ka muna. diba yun breather sa ilalim ng air cleaner assy naka connect. could be that the hose is just loose sa valve cover. yun sa rpm/aircon naman baka need mo adjust yun pushrod na naka kabit sa idle up. timplahin lang. sa aircon shop kayang gawin yan.
BTW, ilan kilometers na tinakbo niyang?
January 17th, 2008 10:53 AM #14
Pre sigurado bang sa breather hose nangagaling yung langis. Mechanical fuel pump ba auto mo? Naexperience ko lang kasi akala ko rin sa breather hose nangagaling yung leak pero sa maliit na butas pala ng fuel pump nangagaling ang leak tumatalsik lang sa hose.
January 17th, 2008 06:54 PM #15
check mo din yung oil level mo baka sobra yung oil. maiitim din ba usok mo?
January 18th, 2008 02:14 AM #16
to afrasay: Yes bro, try na namin i adjust pero d tlaga ma-swak... nsa 105T na tintakbo nya..
to lhandzs... pag tinakpan mo ng daliri ung maliit na breather, ung sa me valve cover, me moist sya...
to eyshmechanic: binabaan na rin po ung oil level... ganun pa rin. mejo white ung usok nya pero pag inalis mo ung hose on both breathers, nawawala na smoke.
ilalagay ko next time ung pic para madescribe ko ng mabuti.
Thanks for all your inputs!!!
Tsikot Member Rank 5
- Nov 2003
- 3,849
January 21st, 2008 02:28 PM #18
thanks sir speedy. Gusto ko sna ibalik kaya lang parang nwalan na ko confidence dun e. baka wala rin mangyari, sayang lang
January 22nd, 2008 01:58 PM #19
bro taga-saan ka ba? though tama advise speedyfix, i can uderstand your frustration. just be ready to spend again on another mechanic.
January 24th, 2008 11:54 PM #20
*H1Tman: oo nga e, nsayang pera... pero ganun tlaga ata. D pa kz ako masyado familiar sa mga auto e. I still considering myself as a "newbie"
Dito lang ako sa me kamuning Area. Thanks bro!
It says CVT daw. For better FC siguro.
Mitsubishi Xforce
