Results 1 to 13 of 13
    guys, help naman.
    Pag start ko ng car sa morning, eh sobrang baba ng idling (350 to 400)...occasionally eh nagdi-dip na ng tuluyan kaya restart uli...ginagawa ko eh inaalalayan ko ng tapak sa gas para mag-start and maintain yun idling. pero pag naka 1km or medyo mainit na makina eh ok na uli...ano kaya problem? may sinasabi yun mechanic na magnetic something and wirings inside the carburetor...is that the reason? car is a '95 mazda 323.
    thx
    your idler up switch might be the problem. ito yon nakakabit sa thermostat. pagmalamig ang makina tinataas niya ang menor mafifeel mo ito sa gas pedal . pag uminit at na sense niya from the thermostat ibababa niya ang menor.
    sir, tinanggal na yun thermostat nya 2 years ago (dinadaanan ng water papunta radiator and engine, ryt?)...pero lately lang sya ayaw gumana...sabi ng mechanic eh may wire daw sila na nakita na walang pagkakabitan...
    thx :D
    Dec 2002
    baka sira yung auto-choke sa carb mo. try mo tanggalin yung air filter mo bago paandarin. have someone to start the engine, while you observe kung mag-sara yung primary. kung ayaw magsara, then auto-choke mo ay di gumagana.
    since may wire kang nasabi, tingnan mo rin yung carb idle solenoid. ito lang yung may electrical connection from the carb. dapat pag-switch "ON" mo may maririnig "klik", meaning ok pa solenoid mo. Or, kung walang connection yung solenoid, dapat ma-connect mo siya sa ignition wiring. try mo, i-hard wire sa battery saka mo paandarin yung engine. feedback ka na lang kung anong nangyari...
    The problem is most likely on your car's timing. Have this thing checked already. :wink:
    ako i had my timing checked almost every week dati dahil ganyan din problem ko. but sometimes pag start sa morning , umaakyat hanggan 2,000 tapos unti unting bumababa, which i think is just normal. minsan naman nasa 500 lang pag start kaya sobra lakas ng nginig kahit i rev ganon pa din. this happens especially pag malamig ang makina. normal ba yun? anu prob? ride ko 96mazdaLX323. help!
    Mar 2003
    Quote Originally Posted by CoolGal
    efi ba or carbs ang auto mo? kung carbs, baka madumi lang. ganyan din sakin dati. bili ka ng carb cleaner. pagkatpos ko linis carbs ko nun, ok na idling. hth.
    Kung yung carb mo ay may "auto-choke" feature na. I agree with the diagnosis above that it's your auto-choke that is no longer working. In my experience, na-stuck lang yung sa akin, ginalaw galaw ko lang to loosen it up, then nag-work na uli. Nabara lang yung hinge niya ng dirt deposits.
    Coolgal,
    We have the same engine and carb. Before, yun rpm ko during morning start is around 1,200 tapos pag mainit na baba na sya sa normal na 800rpm. pag nag-on ng aircon akyat sya ng 900, this is normal. kaso ngayon di na sya tumataas ng 1,200 pag start. ok naman daw yun auto choke kaso di gumagana dahil may wire na hindi sila makabit kse wala mapaglalagyan. 8O
    meron ako carb cleaner and i make it a point to always have my carburetor cleaned once a month. wala naman nangyari, yung first time nilinis naging ok pero after nun ganon na ulit. san un auto choke located?
    yung pagtaas ba ng rpm hanggan 2000 e normal lang pag bagong start:?:
    Mar 2003
    coolgal,
    normal lang sa mga carburated na mga makina ang tumaas ang idling during cold start, eventually pag uminit na magno normal na dapat ang idling mo. i guess 2000 rpm is too much. try to check the springs sa may tabi ng carburator. yung springs para sa gas. baka di na ok ang condition.
    ganon nasisira ba yun parang spring?
    Mar 2003
    yung tension niya nagwe wear out din.
HELP: mababang idling pag-start
