couldnt find any, might poke around and under for a bit. tingin ko meron eh. sana andun lang somewhere.
ay yun thanks. isa lang ang port nya, unlike the other VSV beside it which has two.
i took this off
https://i.imgur.com/7t4vr44.jpg and it is the EGR, while the other is a vacuum modulator and has two ports: top port can draw unmetered/fresh air thru a felt filter and connects to the EGR's top port (and both top ports connect to the thermal switching valve). are they supposed to connect to manifold or are they supposed to be a closed system na silang tatlo lang (EGR/TVSV/vacuum modulator)?
their bottom ports connect each other.
