Results 1 to 6 of 6
- Feb 2003
- 144
February 4th, 2003 01:28 PM #1i have paj. tonka, A/T, nagpapalit ako ng gear oil sa may ilalim dun sa gitna ng front wheels and sa rear diff pati sa transfer case, sae90, pumino and bumilis takbo ng paj. prob lang pag medyo mga 5km na drive ko tapos at full stop turn ko steering wheel to any direction tapos medyo hataw konti may grinding sound lumalabas sa driver side na front wheel, parang gears na dumudulas (note while this is happenning im in 2wd mode (2H)), pero pag naka 4wd naman ok lang walang grinding sound. nde din naman nagbliblink yung wheel indicators ko sa dash. pag umaga pa lang tapos kakaandar lang ng car nde naman ganun...what coud be the prob...
- 10,620
February 4th, 2003 02:18 PM #2grinding? baka naman sa power steering fluid mo, check mo baka kulang na
- Feb 2003
- 144
- Nov 2002
- 70
February 5th, 2003 01:15 AM #5Suggest ko lang kung bago mo pinalitan ang tranny oil mo eh wala kang naririnig na ganyan noon. I would drain the oil immediately and buy the specified oil in your dealer.
Minsan maselan din ang oil weights pag dating sa transmission & transfer case. I-try mo lang kesa masira.
Dito sa tate maraming cases ang ganyan. Parang ang Chrysler, plymouth, dodge & jeep strickly MOPAR ang gamit. Yung benz ko ginamitan ko ng Mobil 1 sa differential anong nangyari ... umugong. Ang ginawa ko bumili ako ng Lubro-Moly which is yun ang ginagamit ng benz talaga. After that nawala ang ugong sa pumino pa at takbo..
I hope that helps...
RIDE ON...8)
- Feb 2003
- 144
February 5th, 2003 11:31 AM #6afrasay, ako yung nagtext sayo dati after mo mag off road..heheheh
actuallybaligtad,pag mlamig wala, pag uminit na after mga 5km takbo yan lumalabas na...
DY3JRM
thx, cge try ko...tatnong ko sa mitsu kung amo tlga recommmended nila...
I also prefer silver. hindi halata na madumi na and some imperfections like faded color and slight...
