Results 1 to 2 of 2
- Nov 2008
- 43
February 12th, 2013 09:33 PM #1Hi,
Ask ko lang sana kung may recommended na autoshop dito pasig na nag hohome service. Ang nangyari po kase yung 1997 corolla ko nagkaproblem sa clutch minsan nawawala so dinala ko sa Petron and they replaced the secondary clutch master kase daw nag leleak naging ok po sya then after 3 weeks ayun bumalik yung issue to the point na need mo na patayin makina para lang matanggal yung clutch.
Since may iba naman ako sasakyan pinabayaan ko lang sa garahe now last week when i try to start it again namamatay na yung engine pag binibitawan yung gas as in derecho 0 RPM then kanina umaga redondo na lang ayaw na mag start.
Appreciate any recommendations you guys can give.
TIA!
- Jul 2010
- 570
February 13th, 2013 10:14 AM #2Kung di gumalaw ang Starter pag start mo ay baka mahina battery. Ilan years na battery mo?
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
