Results 1 to 20 of 20
    Apr 2008
    hyundai excel po sasakyan ko, alaga nman pero biglang may ingay sa makina (takatak), sumasabay pag nagrerevolution.. kapag hinahataw ko ng matagal ( long distance) nawawala yung ingay den about 2 wiks dahan dahan nanamang bumabalik. di nman mausok ang tambucho ko, regular tune-up, and malakas parin humatak?
    ano po kaya sira? overhaul na kaya? normal parin kse ang hatak nya at wala pang usok.
    tulong!!!!
    May 2007
    Quote Originally Posted by slurpieboy View Post
    tulong!!!!
    Your engine sounds like it has a slightly sticking valve. Buy "Marvel Mystery Oil" and put it in during your next change oil. Dont forget to use engine flush(solvent) before draining the old used oil to help remove sludge and restore the rocker arms, valve, valve lifters and piston to improve H.P, fuel economy and performance. That takatak will go away...
    Nov 2003
    it might be the oil. if it's too thick it will not go up into the head which will result in the noise. do a quick oil change and see if it helps.
    Dec 2007
    tulong!!!!
    sir, ano ba ang milyahe ng Excel?? baka due na din to for a Valve Adjustment. also, what yr. is your Excel?
    aite, peace.
    Nov 2007
    sor baka nozzle tip
    Apr 2008
    Quote Originally Posted by v6dreamer View Post
    cge bro, try ko. magkano kaya 1gal nyan? meron ba yan sa ace hardware?
    Apr 2008
    Quote Originally Posted by speedyfix View Post
    kakachange oil ko lang po 3 mos ago, nag engine flush rin ako that time, city drive lang po ako usualy kaya 5mos due ng change oil ko. try ko po ulit pa change oil gamit yung advise ni v6dreamer na MARVEL MYSTERY OIL. magkano kaya 1 gal nun? tnx bro
    Apr 2008
    Quote Originally Posted by KBR View Post
    aite, peace.
    200k++ na bro, 1990 model. regular din kse maintenance ko.
    Apr 2008
    Quote Originally Posted by aga_cruz View Post
    sor baka nozzle tip
    try ko din sir pag nagpa change oil ako this wik. tnx
    Jan 2008
    Di kaya yung engine flush yung dahilan?
    Or baka sa Clutch or transmission galing ang ingay.
    Dec 2007
    wow! well, kung 200K miles na then I bet that the rocker arms (or valve tappets) are wearing out. either way, have the Valve clearance checked and have it adjusted if needed. pero pag na i-adjust na at pag maingay pa din, then theres a possibility na due na yan for a Valve job (or as what they call it in the Philippines, "top overhaul")
    aite, peace.
    Apr 2008
    Quote Originally Posted by youngrider View Post
    b4 ako nag flush and change oil, meron nang ingay bro.
    ang pinagtataka ko lang, pag byahe ako long distance, like 2hrs drive, 90kph average na takbo, nawawala yung ingay for mga 2 wiks den dahandahan nnman bumabalik.
    Apr 2008
    aite, peace.
    oo nga eh, try ko lang muna yung "Marvel Mystery Oil" na suggestion ni v6 dreamer, di ko lang alam meron nun sa davao. pro if still, it doesnt work, then thats the time top overhaul na.
    ang pinagtataka ko lang, pag byahe ako long distance, like 2hrs drive, 90kph average na takbo, nawawala yung ingay for mga 2 wiks den dahandahan nnman bumabalik. papano nangyari yun?
    Bro Try XADO gel bro...I've tried it on my loose compression engine it works...now im still running it with out costly overhaul..try mo lang bro...Before my pickup have a knocking sound ,nawala after i finished the program.... check this: http://www.xado-usa.com
    Apr 2008
    Quote Originally Posted by buggyboy View Post
    sir san ko nman mabibili yung xado na yan? at magkano nman price nya?
    what kind of noise is it? like metal to metal banging? or your excel is beginning to sound like an Isuzu Jeep?
    Nov 2003
    i wouldn't use any additives in the engine. you might screw it up even worse.
    Apr 2005
    up ko lang, paano po ba ginagawa check/adjustment ng valve clearance? tia
    Sep 2006
    tulong!!!!
    Kung diesel ang Excel mo, subukan mo magpa check ng nozzles. Baka meroon kang isang nozzle na stuck up. Good luck.
    Dieseldude
    Nov 2003
    yeah could be air in the system. try to have the fuel rail bled.
maingay (takatak) sa makina
