Results 11 to 20 of 20
June 3rd, 2008 03:45 PM #11
wow! well, kung 200K miles na then I bet that the rocker arms (or valve tappets) are wearing out. either way, have the Valve clearance checked and have it adjusted if needed. pero pag na i-adjust na at pag maingay pa din, then theres a possibility na due na yan for a Valve job (or as what they call it in the Philippines, "top overhaul")
aite, peace.
- Apr 2008
- 12
June 3rd, 2008 03:51 PM #12
- Apr 2008
- 12
June 3rd, 2008 03:57 PM #13oo nga eh, try ko lang muna yung "Marvel Mystery Oil" na suggestion ni v6 dreamer, di ko lang alam meron nun sa davao. pro if still, it doesnt work, then thats the time top overhaul na.
ang pinagtataka ko lang, pag byahe ako long distance, like 2hrs drive, 90kph average na takbo, nawawala yung ingay for mga 2 wiks den dahandahan nnman bumabalik. papano nangyari yun?
June 6th, 2008 11:08 AM #14
Bro Try XADO gel bro...I've tried it on my loose compression engine it works...now im still running it with out costly overhaul..try mo lang bro...Before my pickup have a knocking sound ,nawala after i finished the program.... check this: http://www.xado-usa.com
- Apr 2008
- 12
June 6th, 2008 02:19 PM #15
June 6th, 2008 06:28 PM #16
what kind of noise is it? like metal to metal banging? or your excel is beginning to sound like an Isuzu Jeep?
Tsikot Member Rank 5
- Nov 2003
- 3,849
June 16th, 2008 08:40 AM #17i wouldn't use any additives in the engine. you might screw it up even worse.
July 15th, 2008 12:54 PM #18
up ko lang, paano po ba ginagawa check/adjustment ng valve clearance? tia
- Sep 2006
- 1,335
July 16th, 2008 10:44 AM #19
- Nov 2003
- 3,849
