Results 1 to 11 of 11
    Dec 2003
    Conversion from a saucer type filter to an air filter pwede ba?
    Carb kase yung suzuki fronte ko..
    Saan ba pwede magpagawa nung tube para hindi ako bibili nung saucer type na filter since a saucer type filter is not effective...
    Gagawin ko kase bibili na lang ako ng filter then custom yung tube na gagawin na nakaconnect sa carb ko.Nakita ko kase sa isang mini cooper na luma sa galleries ng tsikot kaya naisip ko kung possible magpagawa na lang ng tube..
    Anong name nung shop na pwede gumawa ng ganitong conversion?
    Thanks...:D
    Sa Lite Ace, may OEM carb adaptor na para gumamit ng canister type air filter (hindi kasi kasya ang saucer type sa ibabaw ng makina).
    Maybe you can grab a hold of a surplus unit and use it on your rig.
    Dec 2003
    Ano ba itsura nung carb adaptor ng Lite Ace baka kase masyadong malaki eh?
    You can try using an "elbow" joint to adapt a straight tube equipted filter, if there is enough clearance between the engine & the hood. I think Simota kits have these.
    Aug 2004
    Asteeeg, may fronte ka?
    tama si ghost, you can use an elbow joint, space permitting... a viable alternative is to have one custom fabbed for the space you have there... yung pinsan ko nagpagawa, L-joint ang labas... it all depends on whether downdraft or side-draft ang carb mo... it's relatively easy.
    Aug 2004
    kung naghahanap ka ng tube try mo sa nodalos. im not sure kung pwede made to order na tube. or if u want bili ka ng k&n na filter... hope nakatulong ako :D
    nodalos can only make galvanized iron tubes. These rust after some time and needs to be painted to look good.
    Best to find a shop with spare simota tubes or selling simota filter kits with tubes included (not necessarily for your car) and try fitting them. You can also have the tube cut in length if needed.
    Dec 2003
    Niky alam mo pala yung suzuki fronte kase nagpagkakamalang toyota starlet yun eh..
    Niky saan nagpagawa pinsan mo ng elbow?
    ghosthunter saan ba maraming nagbebenta ng mga simota especially those tubes?...
    I happened on a "service center" at banawe and their on-site store had a lot of simota kits on display (along with a lot of other stuff like lights, etc.).
    You can also ask Auto_Xer*yahoo.com if he has kits available.
    Aug 2004
    There a quite a number of places that make the tubes, but I haven't had one made, personally... the only one I know of is Kid Audio, in Biņan, Laguna... costs a few hundred for the adaptor to be made, pero GHETTO ung itsura... at least it will be stainless.
    Ahehe... I do have an interest in all things 600cc.
    Dec 2003
    niky so saan si kid audio nagpagawa ng stainless na adaptor?
    Saan sa binan laguna?
    Ano name nung shop?...
    Thanks sa mga replies niyo..
    :D
