honda lxi 97..bakit po kaya pag mainit ang makina ng auto ko hard starting minsan po tinulak pa nmin pra mag start lng.maraming slamat po malaking tulong po sa mga inputs
http://autos.yahoo.com/maintain/repa...ques093_4.html
Hot starting problems can also be caused by cooling problems that allow your engine to run too hot (the pistons swell up and may scuff the cylinder walls), or excessive resistance in the starter motor that causes*the engine*to crank slowly. A starter "amp draw" test can be used to check the condition of your starter. Also, many starters have small "heat shields" to protect them from heat radiating from nearby exhaust pipes or manifolds. If the shield is missing, the starter may get too hot and bind up.*
baka sa ignition coil..
or may problema na sa radiator mo or head gasket,,
Dati nangyari sa akin iyan. Loose thread yun mounting bolt ng starter at dun din nakakabit yun ground wire connection galing - Bat terminal. Loose connection ang grounding ng starter kaya hirap umikot yun commutator. Pero dinig mo mag click yun solenoid.
