Results 1 to 2 of 2
    Tanong ko lang sa mga gurus, is grinding noise limited lang sa defective bearing gear? is this a bearing located where? along the drive shaft connected sa transmission? at stationary (idle) kasi, walang noise ang Revo GLX ko pero pag tumatakbo na may grinding noise. naitakbo ko pa ito ng Bauan (Locloc) at Tagaytay kahapon, ok naman except doon sa nakaka-iritang ingay. sumasabay ang clatter sound sa arankada pero mas maririnig kung nagme-menor. smooth naman ang takbo ng makina at wheels.
    I just want to have an idea as to what extent ang papalitan at gagawin before ko siya dalhin sa mekaniko.
    Last edited by valvura; April 28th, 2008 at 01:38 PM. Reason: Typo error on font size
    Nov 2003
    depends where the noise is comming from. baka naman from a U joint lang or something. if it's from the differential try replacing the gear oil muna. minsan nakukuha dun lalo na if the existing oil is contaminated na.
Grinding sound: Defective bearing gear?
