hi, based on experience, do not use js asakashi oil filter. the ADBV won't work, it will damage your engine due to oil starvation during start-up
check ko dipstick in the morning when the engine has rested for 12 hrs, i noticed that the level of oil is above the maximum about 5-10mm, then i tried to run the engine for 10 mins then have it rest for 30 mins and the level of oil is within the max. further, i change the filter and the old filter was tested in a horizontal position and the oil comes out from the ADBV.
its normal sir.. the adbv is not a check valve or one-way valve.. its just a rubber flap to regulate the oil flow back.. more likely that your engine is over filled with oil..
no sir. when i changed the oil filter after resting the engine for 12 hours, the filter is almost empty, thus, depriving the engine during start-up which is the function of the adbv to prevent the oil in the filter to go back to the sump. it is not overfilled. isuzu 4jk1-tc engine has 7 liters of oil recommended.
There is a possibility thay you may have encountered a defective filter if that's the case. Since one of the official distributors of VIC filters is already carrying JS Asakashi filters as well. So I doubt that one defective filter damages the whole brand besides JS Asakashi filter is also sold in Australia, Russia, Singapore, Malaysia, Sri Lanka, Brunei and etc... if they are a bad quality filter then other countries will not buy their product. If one the offical VIC filter distributor is shifting on selling JS Asakashi filters then that signals something about VIC filters. Do you have any proof of testing about what your saying is true? It's hard to believe in just hearsays of a new member without testing evidences, proper facts and examinations.
There is a video online showing a testing of Dai-wa, VIC and JS Asakashi oil filters.
Dai-wa, VIC & JS Asakashi oil filter pressure test 2020 - YouTube
By the way guys I found videos of air filters on Youtube, they tested the filtration capabilities of K&N, BMG, WIX, Purolator and etc... and the myths of K&N, BMG and other washable filters have been finally debunked. Here are the testing videos about O.E. vs. washable performance filters.
The tests shows that bigger micron flour, sand and iron dusts can pass through more on the washable performance filters with the oil applied on them than standard O.E. type filters. What more for the smaller sized particles like fine particles from electric powerplants, factories, cement dusts, brake dusts and etc... it will wear the engine faster than its normal life.
1st video by Project Farm
Which Car Air Filter is Best? Let's find out! Fram, K&N, Wix, Purolator, & AC Delco showdown - YouTube
2nd video by bhvrdr
Do performance air filters like BMC, K&N, Sprint let more sand and dust than OEM and is it worth it? - YouTube
