Results 1 to 20 of 42
    Dec 2009
    what made you decide to choose petron ultron?
    Aug 2010
    Quote Originally Posted by miko101130 View Post
    sakin lang naman sir di kasi sludge forming ang petron oils, nun binuksan engine cover ng sentra ng misis ko parang bago pa wala ako nakita varnish color 65k sa odo. straight ultron lang ginamit dun.
    I also use Petron Ulton Touring on our old Sentra and Galant (change every 5,000kms) with VIC filter at that. No problems with it unlike what some guys encountered with Castrol before. I also used it on my Altis before switching to Mobil 1000. Its one of the cheaper oils available and since we change every 5000kms, its not causing any problems.
    Oct 2011
    Mukhang sulit itong Petron Ultron even slight cheaper than Castrol.
    Aug 2010
    any feedback on ginza oil filter? top 1 oil?
    Dec 2007
    Quote Originally Posted by trucker111 View Post
    I don't want to start a new topic on this because I already posted about pretty much every oil and their specs sold in the Philippines on the remote bypass filter thread, feel free to search.
    I like to keep the filter stuff in that thread as well but I will answer this one question as I have posted this info before and to save you a long back read.
    OEM filter is the standard we’re using to judge the other seven filters. Based on this standard, the quality of the Replacement filter is patently and grossly inferior, the next most inferior is the Ginza Japan filter. The anti-drain-back diaphragm on the Replacement filter is of very poor quality, so poor that it might even allow unfiltered oil back into the engine the same way it came in. Hence, at the very first stage of a filter’s function, the inferior quality of the anti-drain-back diaphragm on the Replacement filter has already given an indication of how poorly it will perform. Moreover, its poorly assembled filter media as demonstrated by the loosely and highly irregular pleat spacing indicates that it contains far less filter media compared with that on the OEM as well as that of the Vic filter. Because the Replacement filter and the Ginza Japan contain less filter media they consequently must have a diminished ability to filter dirty oil. And finally, under conditions where the by-pass valve will come into play, its by-pass valve has only one .8cm hole for the oil to pass, and the spring on its valve has a resistance that’s nowhere near as stiff as that on the OEM valve.
    In the area of the filter medium, the best was that of the OEM Honda filter which seemed to be of paper/cotton blend. The worst was that of the Replacement “Mazda” and the Ginza Japan filter both of which had very irregular pleat spacing and a smaller filter area than the standard. The Power Long filter was the most unusual being made of stainless steel mesh. It would be much better to subject the different filter media to a genuine test to see which filters the best.
    That was from the mazda club philippines forum.
    Basically they are about the worst filter sold in the Philippines ever worse than VIC.
Good Oil Filter and Oil
