Page 1 of 3 123 LastLast
Results 1 to 20 of 42
    Jun 2009
    Guys, what are the brands of oil filters and type, brand of oil would you recommend for a 2001 2.0L REVO GSX? use for normal driving, and budget conscious.
    best is to follow the recommended oil viscosity based on the manual. then you can choose to DIY or bring it to any gas stations.
    for filter replacement, Vic or Bosch is commonly used though i prefer Bosch
    Nov 2007
    not sure kung maraming autoshop na nagtitinda ng bosch filters but yung VIC filters ang madaling hanapin.
    xto, san ka nakakabili ng bosch filters?
    Oct 2007
    Quote Originally Posted by Esnie.com View Post
    sir, try mo sa:
    [SIZE=3]Grand Luxor - #14 Kabignayan St., Banawe, Quezon City. Contact number nila .. 7120071 [/SIZE]- distributor/retailer po sila ng BOSCH
    Warren Auto Supply
    Benavidez St. near CM Recto, Binondo Mla.
    tel 244-1775
    authorized dealer sila ng Bosch (filters, brake pads, bulbs, horn and battery) and Osram.
    http://rb-aa.bosch.com/boaa-ph/Categ...&publication=1
    double post
    Apr 2008
    royal purple medyo pricey nga lang kasi 500 pesos kada isang litro nito eh
    magnatec ang isang gallon nasa 800 pesos hanggang 1k
    ok din naman ang ibang castrol delo, helix, rimula, rotela, valvoline, enoc, mobil at iba pa
    wag lang REV-X kasi marami nang nabiktima nito tinatawag itong traydor na langis dahil marami na kasi pinakatok na makina nitong langis na'to
    sa filter naman ok ang vic basta lagi lang regular ang change oil mo ayon sa kung ilang kilometers para mag change oil ka kung gusto mo naman mahaba-haba dun ka sa bosch.
    Royal Purple would be nice, (1 year na sa altis ko)
    filters? OEM would be the best. just buy it outside the casa.
    if regular naman ang oil change mo, kahit hindi synthetic oil pwede na. . .ako i do it every 5,000 km or 5 mos; whichever comes first
    always been a combination of castrol and vic for me
    bosch oil filters can be bought in any servitek shops. dyan ako bumibili eh.
    for oils, any recommended mineral oil with the same recommended viscosity for your vehicle would be ok. just have it regularly changed every 5k kms. it will be cheaper than having to fill up with fully synthetic oil tapos once a year mo papalitan, and you can be assured that you always have fresh oil inside your vehicle.
    for oil filters, VIC is also good.
    Apr 2009
    Warren Auto Supply
    tel 244-1775
    Hi XTO ... how much yung bosch oil filter and meron ba sila air cleaner for crosswind xto how much? and ok lang ba oil gamitin ko sae 20/40w
    thanks
    Nov 2007
    Quote Originally Posted by boy_tino View Post
    wag lang REV-X kasi marami nang nabiktima nito tinatawag itong traydor na langis dahil marami na kasi pinakatok na makina nitong langis na'to Are you sure about this? 2yrs ko na ito ginagamit sa 2 diesel na sasakyan ko pero wala naman naging problem.
    pricey na ba ang bosch filters?
    Nov 2007
    Warren Auto Supply
    tel 244-1775
    thanks
    onti lang naman difference, mga 20 pesos to 30 pesos lang.
    Jun 2009
    guys nagpachange oil na ko. vic C-111 oil filter P200, Petron Ultron 20-40w P530, labor P200 bale P930 lahat. Ok Lang kaya yung oil na ginamit ko?????? 8yrs na yung REVO nasa 50,000km na ito. thanks ADVICE nyong
    LAHAT
    ^^yup, ok na yan....
    just had my trooper 3rd Royal Purple 5w-30 in 1 year (napapagala kasi ako parati) and this time Vic Oil filter nalang ginamit ko (2 pcs) kasi malaki ang difference sa price and according to migs, di naman daw ka importante ang oil filters.
    Oct 2011
    I have been using Toyota OEM Oil filter. But as i read from other threads, OEM filters are no good. I have seen brands like puralator, ginza and vic at ace hardware. Are these brands much better than Toyota OEM oil filter? I will use it in my next oil change.
    Read mo yung remote bypass thread. Para alam m fake na Purolator sa Ace. Vic okay up to 5,000kms pero mababa filtration pa din. Bosch is the next readily available na maganda na. Then yung Purolator, fleetguard, baldwin, wix basta orig ay maganda talaga. Nagkaka-ubusan nga lang ng supply kasi alam na ng mga tsikoteers ito.
    Dec 2009
    bro, suggest you read the remote oil bypass filtration on the other thread!
    dame ka makukuha info regarding filters and oils...
Good Oil Filter and Oil
