Hi, I'm confused about this belt stuff, so is the drive belt/serpentine belt the same with fan belt, compressor belt, alternator belt? The car is a Honda Civic 2015 1.8 S AT. Mileage is already at 44k km
Thanks in advance
Thanks in advance
Mas matibay nga siguro kasi I haven't replaced mine which will turn 8 years old in 3 months with 80k+ kms traveled. No signs of slightest fraying, kaya I wondered if the author was just curious or his unit needs replacement na, it's half my mileage and 2 years younger, mine's also a 2013 FB.
Sent from my Mi A1 using Tsikot Forums mobile app
I just want to have the part ready should the inspection from the mechanic turn out to be negative on that part, in any case the car is already 5 years old this 2021 and my aunt is the second owner, I asked for maitainance records and she has none she had relied so much on her previous driver and mechanic, so I might just have it replaced out of caution. I don't want to wait till some signs of a bad belt shows up. heheh but kudos to your car sir tibay nga.![]()
serpentine belts are replaced based on physical appearance or years in service.. some manufacturers suggest to replace the belt every 4 years regardless of its physical appearance.. some maybe even longer around 6 years.
Belts nowadays last longer, just recently replaced a timing belt after 11 years and around 40k mileage, belt had no cracks or damage and looks like it could have gone a few more years given the low mileage per year. But still materials degrade over time. Belts are not too expensive anyway and is included with regular PMS. I recommend getting original part from dealer or having the PMS done at dealership as I have experienced before mas mahal pa sa suking auto shop.
i had my non-honda's timing belt replaced in the casa, on its 14th year / 120K km. it was still less than the manufacturer's replacement schedule. the belt still looked fine to me.
casa, for the perceived genuine-ness of the belt, and the perceived warranty.
the difference between casa cost and banawe cost wasn't that much.
I haven't replaced my 2017 civic's serpentine belt since I got it. It's already 4 years but according to the pms schedule it should be replaced every 3 years. Based on visual inspection, it's still good no signs of cracks and is still thick. Maybe I'll replace it on the 5th year.
Sent from my HD1913 using Tapatalk
many pms manuals assume the car owner is an automotive dumbo,
hence the more aggressive replacement schedule.
after all, that is what pms is all about: pre-failure management scheme. replace it before it brakes.
but if one is knowledgeable, willing to take risks, and does not drive out into the boondocks naman, one can opt for the physical and visual inspection instead.
i do.
some owners have a spare belt in the car, for those justin cases.
i have replaced my 2005 innova's belt with over 140K km on the car,
only once.
somewhere between the 70K and 100K mark, i vaguely remember.
now that you mention it, i think it is time to inspect the belt...
Mine hasn't been replaced since June 2013
Had it replaced a week ago, mechanic said it was a good time to replace, may tama na daw bang belt anytime pwede na bumigay.
Sent from my CPH2159 using Tapatalk
timing belt or "fan belt" ?
how long did this natamaan na belt last since new?
some time ago, a banawe mekaniko recommended that i replace my innova's fanbelt.
after a few weeks, i asked another mekaniko not from banawe, to see if it needed replacement.
"ok pa po. hindi kailangang i-replace."
my over-140K km innova has had its fanbelt replaced only once pa lang.
