Results 1 to 3 of 3
    Oct 2011
    mga sir good im riding nissan sentra eccs 93.
    just wanna know why its hard to accelerate when im using a/c? or is it usual? thanks in advanced..
    Jan 2008
    syempre may load yung A/C compressor eh.. medyo mahihirapan yan.. pero hindi naman sa point na hindi ka na halos mag accelerate... kung ngayon mo lang naramdaman yan.. check mo yung compressor mo baka may sira na bearing sa loob
    Check mo muna baka wala sa correct timing ang makina mo.
    Kung nasa tama naman, try to add 1 or 2 degrees from your current reading mo.
    Halimbawa..ang current ignition timing mo ay 8 degrees BTDC, gawin mong 9 or 10 degrees BTDC...then test
    drive with your A/C on....BUT DON'T OVER DO IT. Adding 1 or 2 or 3 degrees is sufficient....
hirap humatak when a/c is on...
