Results 1 to 3 of 3
- Oct 2011
- 21
January 30th, 2012 02:09 PM #1mga sir good im riding nissan sentra eccs 93.
just wanna know why its hard to accelerate when im using a/c? or is it usual? thanks in advanced..
- Jan 2008
- 4,726
January 30th, 2012 02:16 PM #2syempre may load yung A/C compressor eh.. medyo mahihirapan yan.. pero hindi naman sa point na hindi ka na halos mag accelerate... kung ngayon mo lang naramdaman yan.. check mo yung compressor mo baka may sira na bearing sa loob
- Dec 2006
- 273
February 2nd, 2012 07:19 PM #3Check mo muna baka wala sa correct timing ang makina mo.
Kung nasa tama naman, try to add 1 or 2 degrees from your current reading mo.
Halimbawa..ang current ignition timing mo ay 8 degrees BTDC, gawin mong 9 or 10 degrees BTDC...then test
drive with your A/C on....BUT DON'T OVER DO IT. Adding 1 or 2 or 3 degrees is sufficient....
You can add , The Ten Commandments, BenHur ....
Traffic!
