Results 1 to 4 of 4
    Apr 2014
    Kailangan nang palitan ang valve cover gasket ko kasi nagle-leak na yung oil sa mga gilid ng valve cover ..
    Bumili ako sa casa ng oem valve cover gasket .. Plano ko na sanang ipalagay, kaso sabi ng mekaniko baka kailangan na rin daw palitan ang Spark Plug Oil seal pag nabuksan na yung valve cover at hardened and shrink na ang seals baka mag cause ng leak sa spark plug wells pag ibinalik ang valve cover na hindi na palitan ang spark plug oil seals ..
    Sa CASA, nasa P400 ang isang spark plug oil seal, eh dapat 4 ang bilhin ko .. masyadong mahal .. anong magandang brand ng spark plug oil seal replacement outside sa CASA ..
    Sa ngayon, valve cover gasket lng ang may leaking ng oil .. yung 4 na spark plug wells walang leaking, meaning tight pa ang spark plugs seal .. hindi ko lang alam kung luluwag yun pag natanggal na ang valve cover pag replace ng valve cover gasket kaya gusto kong maniguro ..
    Kailangan ba talagang palitan rin ang spark plug oil seals pag nagtanggal ng valve cover ???
    Feb 2009
    Your gasket kit should have that included already. Or you buy them separate. If you have difficulty finding them, remove carefully for reuse. When you reuse them, clean the grommets thoroughly with soap and water, dry and coat with sensor safe etc sealant prior to reinstallation
    Oct 2009
    palitan mo na bro kaysa mag dalawang trabaho kapa.sa labas muna lang yan naka bili ako 100 lang isa
    Apr 2009
    Personally speaking, I will buy the OEM set then install it myself. If you plan on keeping your car for an indefinite time then OEM is the way to go. Not necessarily sourced out from the Casa as they sell it more expensive. You can always buy them in Toyota specific reputable shops in Banawe or anywhere. If you are good with hand tools, this is a DIY shop in less than 2 hours....
Corolla 4afe 1.6 Valve Cover Gasket needs to be replace ...
