Results 1 to 10 of 20
Threaded View
September 15th, 2013 12:42 PM #16
Sir Jiggs answered your comment. I hope you'll stop praying.
Sumasama din sa combustion chamber ang oil. What determines if it will become gas is the temperature and PRESSURE inside the chamber. (You can boil water at zero degrees celsius) Once it changes to gas state, the hydrocarbon engine oil will ignite. Engine oils are hydrocarbons with additives like zinc, zinc will still be zinc and will not participate with the fuel-oil-oxygen combustion. It will be in a gaseous state though and will pass thru the cat con.
That's what they (API and car manufacturers) say.
Having an API license is expensive, but if you do have it, car manufacturers will promote your oil.
It's all about money.
have your compression checked... if Manual yang Montero mo... try mo patulak if ayaw mag start...
