Results 1 to 5 of 5
    Hi Mods don't know it this is the right forum for this.
    My brother gave me a fuel enhancer it is called a fuel saver.
    After using 2 tablets in 3 weeks; the effect was phenomenal.
    My car did not consume any fuel for the next 3 more weeks.
    Why?
    The car cuts out at idle, it cuts out during a high speed operation.
    I never used the car again.
    Should I drain the tank?
    Drain the tank. Have it cleaned as well while you're doing this.
    Replace the fuel filter. Probably clogged up with the "fuel saver" based on your description.
    Purge the fuel lines between the filter & tank.
    Charge the cost of the service & wasted fuel to your brother's wallet.
    Feb 2010
    yup...charge it to bro's wallet.....have the tank drained......use high grade fuel once finished.....don't used cheap fuel filters also.....so as not to double your expense
    Aug 2004
    Quote Originally Posted by reym View Post
    Why?
    Drain your tank, change your fuel filter. Most of those tablets contain some form of octane booster and detergent. It's possible there was too much detergent in the pills and it clogged your filter and/or your pump.
    Dapat testimonial ka sa TV.
    * Nicky, sayang alang kumuha sakin artista mag testimonial nga sana ko,
    I brought down the tank, the fuel was so murky kakulay nung fuel saver, pati ung mga silver silver nya nakuha ko naman sa fuel filter. Pero bat ganun may roon din mga buhangin?
    Ayun binaba ko ung carb, bought carb cleaner at overhauling kit, plus fresh gasoline. Cost me P 1,000 pesos.
    Pero she is running fine na. Nasayang rest day ko, nakapag review sana ko for certification exam daym ...http://www.polysolve.com/index.php/1...959dc19e019920
Fuel Saver 100% Effective
