[SIZE=2]newbie here.,just want to share my personal experience on fuel pump malfunction.i had also the same ride,,94honda civic esi.last 4months ago lang to.i was driving at a moderate speed,tpos right after magshift gear ako e bigla na lang naging bumpy,,kumkadyot talaga yung oto ko for a second then mawawala tapos nung magaccelerate na ulit ako e ganon na naman.kinabahan na ako kasi baka kako sa makina ko na yung may problema.then i decided to stop at the nearest talyer or any gas station to take a clear check.sabi ng mekaniko e supply daw ng gas kasi baka daw may nakabara o baka daw kailangan na palitan ang fuel filter,when he asked me 'bout the previous symptoms..we check fuel filter--ok pa daw..tapos nung start na e hindi na magtuloy,,may supply ng kuryente pero walang supply ng gas..yun na!..we ended up at fuel pump after checking it..sira na nga,malakas na yung alog dun sa loob,parang kalas-kalas...after installing a new one,,hoolahh,,ok na..as of now e wala pa naman ako nararamdaman kakaiba.ok na ulit ung takbo ng oto ko after that..
btw,that fuel pump unit alone cost me Php2500..
HTH
[/SIZE]
