Results 1 to 6 of 6
    Apr 2011
    ayaw mag start mga sir ung oto ko my gas naman. pati my battery. pag iniistart d tumutuloy ung andar. pls help. thx thx
    ano oto?
    The message you have entered is too short.
    Jan 2010
    Quote Originally Posted by guitar_guru View Post
    Can you clarify please, TS? When you said "pag iniistart di tumutuloy" do you mean when you turn the key nothing happens, or when you turn the key, it makes the starting sound then it dies?
    If it is the first, you might want to check your fuses and make sure these are not burnt, and that these are properly seated.
    If it is the second, there are two possibilities: your battery is dying and cannot provide adequate start up power; or, there's a clog in your fuel line or fuel filter. You might want to try to crank your vehicle... check your manual for the proper process for your specific brand and model.
    Have you done any other diagnostic tests? Have you tried turning on your wipers? Try turning it on to see if it swipes normally or if it is oddly slower than usual. Such would indicate low battery power or an issue with your electricals. Also check your spark plugs.
    By the way, what is the brand and model of your vehicle? Please give us as much detail about your car to help in the diagnostics.
    Apr 2011
    sir thank you nissan sentra series 3 po. * digitalron sir thank you!!!. pero ok na oto ko wala palang gas sira ung meter para sa gas. nasa 1/8 pa pero wala ng gas. cguro sira ung meter niya.
    pero tumataas naman pag ng lalagay ako ng gas. nagtataka lang ako bakit 1/8 pa ung nasa meter wala ng gas? diba dapat sa empty pa? ung isa nga namin oto kahit lagpas pa sa empty meron pa. e bakit kaya 1/8 empty na tpos di umiilaw ung warning sa gas. diba pag empty na iilaw ung warning? alam ko naka float ung meter sa gas tank diba?
    san ba pwede ipagawa un? thx
    malamang sa malamang yung float may kasalanan. saan area mo? sa south kay hongly sa sucat, speedyfix sa shaw, motorcraft sa banawe.
    Apr 2011
    sa taytay rizal po.
my car wont start pls help
