Results 1 to 16 of 16
    Apr 2009
    Anyone tried using it already as a temporary fix for leaks in head gasket?
    Sep 2008
    It could be a temporary fix but it is a case to case basis. Kapag masyado ng malaki ang butas, I doubt if it will work
    Quote Originally Posted by bail View Post
    It will work if the damage isn't that extensive..
    Feb 2009
    Before anyone jumps to conclusion or guess, first identify what is leaking. Is it fluid or gas? If it is fluid, is it antifreeze/coolant, fuel or lube oil?
    Mar 2004
    Ditto ... just had "engine" leak repaired ... went to 2 shops who diagnosed it as a front wheel bearing / gasket leak and repair would cost about 2000++ ... went to dealer and diagnosis was to tighten power steering hose ... cost to repair only 420.00 ...
    Jul 2006
    If head gasket leak is the main culprit (proven, tested, confirmed), then the only fix for that is a new head gasket.
    if you're stuck somewhere in the boondocks, it may work but I'd rate that possibility to a slim 10% over a 100.
    i haven't tried it.
    my concern is, it might block the coolant passages, resulting in overheating, localized or generalized.
    who has tried it here?
    DON'T use it !!! There are no shortcut remedies for such problems. Go find a competent shop and have them replace the head gasket.
    Sent from my SM-T230NU using Tsikot Forums mobile app
    Mar 2017
    as others suggested if it's indeed headgasket issue get it fixed. it's not that hard to change that.
    Mar 2017
    As a temporary fix, I think it would work.
    If you decide to try, please let us know the result (grin)
    Jun 2017
    Depende s kung gaano na kalaki ang problema, but hindi talaga sya pang long term na fix. .
    Sent from my BLN-L21 using Tsikot Forums mobile app
    Jun 2017
    Hello po. I'm a newbie here. Magpapatulong po sana ako. I need your advices po. My car is a '95 Nissan Sentra Super Saloon (GA16 yung makina)
    Recently, my car engine overheated. Naghahalo yung oil and tubig. Dinala ko sa isang car care shop, unang diagnosis was top overhaul lang. Tinanggal na nila yung cylinder head then sabi nila may linya na daw yung liners kaya ipapagawa na din sa machine shop. Pinaresurface yung cylinder head, pina grind yung crankshaft, nagpapalit ng sleeve, piston at piston rings, valve seals. Took a week bago nagawa, then kinabit na lahat, changed the oil. Nirelease na after days, pero sobrang usok kaya binalik ko then nakita na humahalo pa din. Ang ginawa na naman sa cylinder head is pina hydro test then wala naman nakitang crack, pero sabi nung mekaniko may nakita daw silang crack palitan na daw yung cylinder head. So yun, nagpalit kami ng surplus worth 16k. Pina overhaul din yung radiator.
    Then ok na daw, hindi ko pa masyadong ginamit kasi mausok ng sobra pero dahil lang daw yun sa sinusunog yung bagong parts. I checked the radiator cap naghahalo pa din yung oil and water. Ang sinasabi ng mekaniko is may tama na naman daw yung cylinder head. Ang pinagbilhan ko nun is a credible dealer of car parts (CBROS) and kakilala namin so good one yung binigay. Ano po ba sa tingin nyo yung sira? Yung mekaniko kasi parang hindi naman talaga marunong pa. Gusto nya palit lang ng palit hindi nya naman nakikita kung ano talaga yung sira. Sorry po for the long post. Please help thanks a lot po!
    Sent from my ASUS_T00J using Tsikot Forums mobile app
    Apr 2009
    Quote Originally Posted by ibysa View Post
    Saan shop yan?
    Jun 2017
    HPE Car Care po.
    Oct 2013
    HPE Car Care po.
    Bicol ka ano? Palit ka na shop.
    Jan 2010
STOP LEAK head gasket remedy,is this effective?
