Results 1 to 8 of 8
    Apr 2009
    Im planning to change my timing belt and failing water pump already, what other parts should i also change para sulit sa labor?
    Jul 2010
    Quote Originally Posted by bail View Post
    You can also change the crankshaft and camshaft oil seals when the timing belt is replaced.
    Apr 2013
    Sa 4afe gli yan? Sama mo na din yung mga drive belts. Alternator belt, ps pump belt, compressor belt. Optional lang naman yan. Bando is a good brand.you might as well change the spark plug oil seal since nasa valve cover naman yun at magbubukas din ng valve cover. Pero optional lang din naman yan. Camshaft and crankshaft Oil seal, timing belt,and water pump talaga ang "must change" dyan.
    Apr 2013
    Timing belt
    Tensioner bearing
    Camshaft and crankshaft oil seal
    Water pump
    Optional:
    Ps belt
    Altenator belt
    Ac compressor belt
    Spark plug oil seal
    Jul 2006
    Sa ibang models ng kotse, meron mga idler bearing/s na dapat din isama sa pag-palit.
    Then may balancer belts pa.
    Apr 2009
    Car ko pala is corolla 1997 1.6 gli 120k mileage Napalitan na yung oil seals crankshaft and cam shaft 3 yrs ago so ok lng palitan ulit? By the way pwede ba to pagawa sa servitek? Kaya ba nila ang ganun service?
    May 2011
    The timing belt kit includes:
    Timing belt
    Camshaft seals - 2ea
    Front crankshaft seal
    Idler pulley
    Tensioner pulley.
    Not included is the oil pump seal
    All these parts need to be replaced for your 4afe.
    This task takes about 3.5 hours by an experienced technician with the necessary tools.
What other parts to change when changing timing belt and water pump?
