Results 1 to 10 of 10
    Jul 2006
    Mga sir kelan po ba dapat naglilinis ng fuel injectors?..
    85k na po tinatakbo ng sasakyan.. Kelangan na po ba palinins yun?
    Usually po mga how much? May tinanong po kasi ako 1,200 po recon dun sa apat.. May nagsasabi naman po sakin na 150 lang daw isang linis nun?
    Sa glow plugs naman po.. Ok lang po ba na replacement lang lagay ko?..
    Salamat po mga tsikotsters!..
    Sep 2006
    Quote Originally Posted by TOiNk-19- View Post
    What is your car / engine?
    May nararamdman ka bang problema sa car mo?
    Jul 2006
    Quote Originally Posted by Dieseldude View Post
    4d56 po.. Wala naman po sir.. Yun nga lang may nakapag sabi po na dapat ko na po linisan yun..
    Also po para ang ingay po ng makina ngayon after palitan ng timing belt..
    I think what they meant is kung no more than nozzle cleaning lang, 150 each. peru kung ayusin ang nozzles, 1,200. though I never heared of nozzle reconditioning. could be wrong though...
    I believe Bosch's Zexel or Denso yung nozzles niya.
    afaik, denso injectors are cheap yung nabili naming sa Denso outlet mismo, 2 years ago only costs 300 pesos each. may casing pa.
    ....don't forget the right nozzle pressure for your 4d56.
    hard cold start 4d56 mo? kung hindi naman, wag na.
    Sep 2006
    4d56 po.. Wala naman po sir.. Yun nga lang may nakapag sabi po na dapat ko na po linisan yun.. Hindi mo kailangan magpa repair ng injectors kung wala ka naman nararamdamang problema. Sayang lang gastos mo.
    Also po, para ang ingay po ng makina ngayon after palitan ng timing belt..Check injection pump to engine timing. Baka hindi lang nailagay sa exact timing ang injection pump nung magpalit ka ng timing belt.
    Nov 2003
    have it calibrated na derecho if may problem. no need na to have it cleaned.
    Jul 2006
    Okei.. salamat po mga sir..
    Godspeed!..
    Jan 2010
    ok lang replacements glow plugs but of course you can only get what you paid for. i've tried "federal mogul" and it only lasted more than a year, i think its P200 by the time i bought it. ung nkakabit ko ngayon is "kitahara" worth P300 its now 3 yrs old and counting, sana magtagal pa hehe. mahal kasi ng original last time i looked for it, they quoted me P1400 each
    Jan 2010
    hello mga kapaj!
    pwede ba ako magtanong sa inyo kung anong marecommend nyong airfilter for 4m40? and saan makakabili.
    Jan 2010
    hello mga kapaj!
Fuel injector & Glow plugs..
